How long would it take to get to Alpha Centauri?
In summary, the conversation discusses the time it would take to travel to Alpha Centauri at different speeds, taking into account the warping of space-time. The equation used is (4.37/.9) √(1 - (.9)^2) and it can be modified for different speeds. It is suggested that a speed of 0.09c would be sufficient to reach Alpha Centauri in 50 years from the spaceship's frame of reference. Other calculators and considerations for comfortable travel and advanced technology are also mentioned.
yoyopizza
39
So Alpha Centauri is about 4.37 lightyears from earth, but that's in Earth's frame of reference, if you could build a spaceship to go, say 9/10c relative to Earth how long would it take to get to alpha centauri, because then space-time would be warped and therefore it would no longer be 4.37 lightyears away relative to the space craft. Also what equation did you use so I can modify it if it takes to long(i'm writing a story, and it needs to be reasonable like 50 years or so if possible)
How long for who, someone on the spaceship or someone on earth? For someone on earth, it would appear the ship took (4.37 / .9) years to arrive. For someone on the spaceship, it would appear to take less time: (4.37/.9) √(1 - (.9)^2)
Plug other numbers in for .9, as you see fit.
When you put (4.37/.9) √(1 - (.9)^2), is that (4.37/.9)* √(1 - (.9)^2), or (4.37/.9)/ √(1 - (.9)^2)
The first one.
Also, note that if ~50 years (from the spaceship's) reference frame is what you're after, you only need the ship to travel at around 0.09c. At this speed, relativistic effects are sufficiently small that it's only a couple months longer in the Earth's frame.
I don't know what problem you're trying to solve but the one the OP stated requires a speed very, very close to that of light, slightly faster than 0.999934c.
Huh? To get to alpha centauri in 50 years? Even for Earth time, it's only 4.37 light years, so 1/10 c would take 43.7 years to get there.
I think it would be helpful if you explained which problem you are trying to solve. The OP's problem was going to Alpha Centauri in 50 years (according to the rocket's frame) which is what I solved.
You guys are right. For some reason, I was thinking the distance was 4370 light-years, so I was the one that was misrepresenting the OP's problem.
Thanks for the correction and sorry for the mixup.
To yoyopizza:
Travel to a distant star needs to be realistically comfortable for the travelers. That implies that spaceship acceleration (to speeds near light speed) should be about the same as the gravitational acceleration one experiences on Earth, namely 1g (which = 1.0326 ly/y^2).
Accelerating at 1g to the midpoint and then decelerating at 1g from midpoint to Alpha Centauri will result in a trip time of about 3.58 years on the travelers’ clock and 6.00 years on Earth’s clock. At midpoint the speed will be about 0.952 c.
To yoyopizza:
I should have mentioned in the earlier reply that your story need not be limited to traveling to Alpha Centauri. With 1g acceleration/deceleration any galaxy/star in the observable universe (that is, out to about 13.7 BILLION light-years) can be visited with less than about 45 years of traveler's time.
The amount of energy needed to uniformly accelerate a spaceship at 1g for billions of light years is astronomically large. I suspect it would violate yoyopizza's requirement of "reasonable".
To LastOneStanding:
Yes of course, if you have to carry all the needed fuel at take off (old technology).
But what if technology has advanced to the point where the ship can gather its fuel components from intergalactic space (Hydrogen, Helium), manufactures what's needed, and exhausts it at higher velocity?
Thanks guys this should be more than enough, when I mentioned 50 years I just meant it had to take less than that. Also, thank you Bandersnatch for the calculators, I plan to use them in the future!
Related to How long would it take to get to Alpha Centauri?
1. How far away is Alpha Centauri?
Alpha Centauri is approximately 4.37 light years away from Earth. This equates to about 25 trillion miles or 40 trillion kilometers.
2. How long would it take to travel to Alpha Centauri?
At our current technological capabilities, it would take approximately 137,000 years to travel to Alpha Centauri using conventional chemical rockets. However, with advancements in technology and the development of faster propulsion systems, it could potentially be shortened to 20-50 years.
3. What is the fastest spacecraft that has been sent towards Alpha Centauri?
The fastest spacecraft to date that has been sent towards Alpha Centauri is the Voyager 1 probe, which has a speed of about 38,000 miles per hour. At this speed, it would take about 80,000 years to reach Alpha Centauri.
4. Can humans survive a journey to Alpha Centauri?
With current technology, it is highly unlikely that humans could survive a journey to Alpha Centauri. The journey would take too long and would expose astronauts to high levels of radiation. However, future technology and advancements in space travel may make it possible for humans to safely travel to Alpha Centauri.
5. What is the closest we have come to sending a spacecraft to Alpha Centauri?
The closest we have come to sending a spacecraft to Alpha Centauri is the Breakthrough Starshot initiative, which aims to send a fleet of tiny spacecrafts called "nanocrafts" to Alpha Centauri at speeds of up to 20% the speed of light. This project is still in the development phase and has not yet been launched.
  • Astronomy and Astrophysics
