How many amps can I generate with a dc motor?
In summary: Test on one motor roughly agreed with preceding.The faster you spin the motor, the more volts you'll get - somewhat!... it depends on the circuit you attach it to! A low resistance will increase the current and decrease the volts.
Trimacon
I want to use a 12V DC Brushless permanent magnet motor as a wind powered electrical generator for a project. The motor is rated DC 12V and 1.20 amps. Once I reach an output of 12V does that means that I also have 1.2 Amps?
Thank you.
Tried to find answer to this years ago and was never able to, so made following assumptions.
Small Motors are very inefficient, say only 50%.
So effective power to motor is only 6V and 1.2 amp.
Motor operating as generator is only 50% efficient, so output from motor is only 0.6 amp.
So your output is only 6V and 0.6 amp.(assuming motor/generator is turnin at rated motor speed.
Would really like for someone to give a scientific explanation of the actual output.
Think more about the power you are putting into rotate the rotor of this motor. What happens to that power when you attach a load?
You'll end up with [pure theory, discounting losses, &c.] Power-in=Volts x Amps, and Load resistance = V/I. Two variables (V and I), two knowns (Power and load). [This is very idealised.]
So you can see that volts and amps are dependent on power and load.
One thing to remember about using a DC generator to, e.g., charge a battery is that you have to include some means to prevent the battery from discharging back into the generator when it is no longer 'generating'. The output volts have to stay above the volts of the battery (and not too far above either, else the battery will overcharge).
Preventing the discharge can be done with just a simple diode, but if you are, for example, charging a 6V battery with a diode with a 0.6V forward voltage drop, you are losing 10% of your input power to the diode. Similarly, if you end up generating 10V because your generator is running fast, then if you are running a simple linear circuit you'd need to dump 40% of the power.
Clever switching circuits are needed to efficiently manage the power coming out of, particularly, wind generators for reasons of their (obvious) speed variability...and the emphasis is, indeed, usually on 'efficiency', because 'energy optimisation' is the name-of-the-game if you're already bothered to build a wind generator!
I would imagine that what you'd want to do for an efficient DC wind generator is to find one that generates high volts, thus low current and the diode wouldn't suck up such a big percentage of losses, then feed capacitors from which you use a switching scheme to draw the power off them. As the generator drops below the level where it is feeding volts onto the capacitors, it'd 'unload' a little and the output volts would go up again. This should therefore reach some balance where it runs pretty much at a rate that generates the volts enough to cross the diode to the caps, and current to supply the power demand on the other side of the switching circuit. This is just a guess, I am sure there are heaps and heaps of pages on DIY wind power management on the www.
Thank you.
A 'brushless' DC motor still needs a commutator function - it's just done electronically rather than with a commutator and brushes. I would suggest that, (unless someone can tell us they have used one successfully! haha) this could be a problem, as the switching circuit circuit would need to be measuring voltages and switching appropriately.
If you have this sort of motor, though, it wouldn't be too difficult to remove the switching circuit and use it as a multiphase Alternator. Follow this with suitable rectification and you're back with DC and no discharge problem. Look at google images of a brushless DC motor and an alternator. You will see what I mean.
I did that and removed the circuits. I will add a full bridge rectifier to have dc output, but my question is still how many amps would come out if the output voltage is 12V.
It will depend on the rotation rate and the field - and the resistance of the coils. I suspect the output power would be similar to the output power when used as a motor?
Related to How many amps can I generate with a dc motor?
1. How is the amperage output of a DC motor determined?
The amperage output of a DC motor is determined by the amount of current flowing through the motor's windings. This current is dependent on the voltage applied to the motor, the resistance of the windings, and the efficiency of the motor.
2. What factors affect the amperage output of a DC motor?
The amperage output of a DC motor can be affected by several factors, including the voltage supplied to the motor, the size and type of the motor's windings, the efficiency of the motor, and the load placed on the motor.
3. How can I increase the amperage output of a DC motor?
The amperage output of a DC motor can be increased by increasing the voltage supplied to the motor, using larger or more efficient windings, or reducing the load on the motor. However, it is important to note that the maximum amperage output of a DC motor is limited by its design and cannot be increased indefinitely.
4. What is the typical amperage output of a DC motor?
The typical amperage output of a DC motor can vary greatly depending on its size, type, and application. Small DC motors used in household devices may have an amperage output in the range of 0.1-1 amp, while larger DC motors used in industrial applications can have amperage outputs of several hundred amps.
5. Can I use a DC motor to generate electricity for my home?
While DC motors can generate electricity, they are not typically used for powering homes. This is because the voltage and amperage output of a DC motor are not regulated and can fluctuate greatly, making them unsuitable for powering household appliances. Additionally, the efficiency of a DC motor as a generator is usually lower than dedicated generators or alternative energy sources.
  • Electrical Engineering
