How Many Basis Vectors in Hilbert Space?
In summary: I'm not sure whether the word is equivalent, or perhaps isomorphic)... and this helped to convince many skeptics that the two approaches were really just two different ways of saying the same thing - a widespread belief that persists to this day. But I don't know if this has any bearing on the usage you quote, or whether this is just a red herring.In summary, the dimensionality of a Hilbert space is not limited by its rules and can be both finite and infinite. In terms of physics, "the Hilbert space" or "Hilbert space" is often used to refer to any infinite-dimensional separable Hilbert space, which can be isomorphic to l^2. However, this usage may not be
RyanUSF
What is the dimensionality, N, of the Hilbert space (i.e., how many basis vectors does it need)?
To be honest I am entirely lost on this question. I've heard of Hilbert space being both finite and infinite so I'm not sure as to a solid answer for this question. Does the Hilbert space need 4 basis vectors to generate the 4x4 matrix of spin orientation (up up, up down, down up, down down). Could someone please clarify this for me?
There is no "the" Hilbert space. Hilbert spaces are a type of mathematical object. For comparison, examples of other types of mathematical objects include groups, rings, and vector spaces.
To be a Hilbert space, you just have to follow a common set of rules like "have an inner product" and "the inner product of an element against itself is greater than or equal to 0". The Hilbert space rules don't limit the number of dimensions. Different Hilbert spaces have different numbers of dimensions, both finite and infinite. You could have any number of basis vectors.
There's this odd sentence on the Wiki for Hilbert Space though: <<Most spaces used in physics are separable, and since these are all isomorphic to each other, one often refers to any infinite-dimensional separable Hilbert space as "the Hilbert space" or just "Hilbert space">>. So it seems that there's a physics slang in which "The Hilbert space" means "isomorphic to l^2"?
Likes Demystifier
Oh, I see. Based on your quote, it sounds like "The" Hilbert space is infinite dimensional and so will have infinitely many basis vectors. It also sounds like a terribly misleading name (I guess saying "The Infinite Separable Hilbert Space" gets tiring).
Given that information, the space occupied by a finite number of qubits or spins is not "the" Hilbert space. The state space of ##n## qubits is ##2^n## dimensional and "a" Hilbert space, but it is not "the" Hilbert space because it is not infinite dimensional.
I suppose. Maybe it's because spin alone doesn't account for the whole physical configuration. Or Wikipedia is misinterpreting the reference.
Finite dimensional "Hilbert spaces" are customarily called Euclidean spaces of given dimension.
I will be more succinct than some of the other posters.
A Hilbert space is an inner produc vector space that is complete.
I could spell out what each of those terms mean, but it is a good exercise to investigate them yourself:
https://www.math.washington.edu/~greenbau/Math_555/Course_Notes/555notes5.ps_pages.pdf
If you have any problems post here.
It is usually complex in QM but can be over the reals or quaternions. There is something in the back of my mind a theorem due to Soler shows that they are the only possible options, and since the real and complex number are subsets of the quaternions, a quaternion space would be the most general space. But don't hold me to it.
In QM it is usual to impose the condition of a countable basis. Again its a good exercise to investigate exactly what countable means.
If you want to understand at a deeper level what's going on in QM you should investigate Rigged Hilbert Spaces which are a generalisation of Hilbert spaces. Be warned though - that will require a fair amount of effort - its what mathematicians call non-trivial.
Thanks
Bill
Talking about quaternions... Most of variables in QM are complex-valued. But as complex numbers are subset of quaternions, how do we know that they are not quaternions, "almost degenerated (but not exactly)" to complex numbers?
There are some theorems of Piron and Soler that almost, but not quite, proves it must be complex. If one adds the so called plane transitivity axiom then the proof is complete:
http://arxiv.org/pdf/quant-ph/0105107v1.pdf
Thanks
Bill
What about octonions?
Ruled out in QM due to the theorems I mentioned.
Thanks
Bill
Physical theorems are so full of "hidden assumptions" that I hardly believe them.
I believe that long, long, ago, l^2 was affectionately called "Hilbert's space". John von Neumann gave the first complete and axiomatic treatment of abstract Hilbert spaces, as well as naming this concept; and he did this specifically with a view to getting quantum theory onto firm mathematical foundations. As a side effect, Heisenberg's matrix mechanics and Schrödinger's wave mechanics could be shown to be mathematically equivalent.
Likes vanhees71 and bhobba
Related to How Many Basis Vectors in Hilbert Space?
1. How many basis vectors are there in Hilbert Space?
There are infinitely many basis vectors in Hilbert Space. This is because Hilbert Space is a mathematical concept that can have an infinite number of dimensions.
2. Can Hilbert Space have a finite number of basis vectors?
No, Hilbert Space cannot have a finite number of basis vectors. This is because Hilbert Space is defined as a space with an infinite number of dimensions, and thus requires an infinite number of basis vectors to span the entire space.
3. How are basis vectors chosen in Hilbert Space?
Basis vectors in Hilbert Space are typically chosen to be orthogonal (perpendicular) to each other. This means that they are linearly independent and can span the entire space without redundancy.
4. Are there different types of basis vectors in Hilbert Space?
Yes, there are different types of basis vectors in Hilbert Space. The most common types are the standard orthonormal basis vectors, which are typically used in quantum mechanics, and the Fourier basis vectors, which are used in signal processing and harmonic analysis.
5. How do basis vectors relate to the dimensionality of Hilbert Space?
The number of basis vectors in Hilbert Space corresponds to the dimensionality of the space. For example, a Hilbert Space with three basis vectors would have three dimensions, while a Hilbert Space with an infinite number of basis vectors would have infinite dimensions.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
