MHB How many bills of each type are there in a wallet with $\$460$?
  • Thread starter Thread starter bergausstein
    Money
The discussion revolves around determining the number of $5, $10, and $20 bills in a wallet totaling $460, based on specific relationships between the quantities of each bill type. The user initially solved the problem using two different methods, arriving at 14 $10 bills, 8 $20 bills, and 32 $5 bills. A third method, using $5 bills as the variable, led to confusion and an incorrect conclusion of 35 $5 bills. The user seeks clarification on deriving the number of $20 bills in terms of the number of $5 bills, specifically how to arrive at the expression $\frac{x-16}{2}$. The discussion highlights the importance of correctly setting up equations based on the relationships between the bill quantities.
bergausstein
A wallet has $\$460$, in $\$5$, $\$10$, and $\$20$ bills. the number of $\$5$ bills exceeds twice the number of $\$10$ bills by $4$, while the number of $\$20$ bills is 6 fewer than the number of $\$10$ bills. how many bills of each type are there?
i solved this problem in two ways by 1st choosing the unknown represent the number of $\$10$ bills and 2nd by choosing the unknown represent the number of $\$20$ bills.
and i got these answers from my two methods, $14$ $\$10$ bills, $8$ $\$20$ bills and $32$ $\$5$ bills.
on my third method i chose the unknown represent the number of $\$5$ bills.
and here how it goes,
let $x=$ number of $\$5$ bills,
$\frac{x}{2}-4=$ number of $\$10$ bills
$\frac{x}{2}-4-6=$ number of $\$20$ bills
$5x+10\left(\frac{x}{2}-4\right)+20\left(\frac{x}{2}-10\right)=460$
$5x+5x-40+10x-200=460$
$20x-240=460$
$20x=700$
then, $x=35$ ---> from here the number of $\$5$ bill is bigger than my previous result. can you pinpoint where is the mistake here? thanks!
p.s use only one variable.
Mathematics news on Phys.org
If $x$ is the number of \$5 bills then:
$$\frac{x-4}{2}$$ is the number of \$10 bills.
$$\frac{x-16}{2}$$ is the number of \$20 bills.
if i use that $x=32$ which is the number of $\$5$ bill. thanks!
if some question why did you divide $x-4$ by $2$? in my first method what the number of $\$5$ bill is $2x+4$
that's why i thought of taking the opposite operation so i came up with $\frac{x}{2}-4$.
If $x$ is the number of \$5 bills and $y$ is the number of \$10 bills, then we have:
$$x=2y+4\implies y=\frac{x-4}{2}$$
I think you might have solved this problem already, but just for practice can you show how to get the number of \$20 bills in terms of $x$? MarkFL showed how to get the number of \$10 bills but didn't show all the steps as to how he got $\dfrac{x-16}{2}$ for the number of \$20 bills. Can you show how to get this value? :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
