MHB How Many Books Did Devi Read in a Month?
  • Thread starter Thread starter Johnx1
    Books
Tom and Devi read a total of 34 books, while Devi and Weiming read 58 books together. Weiming read twice as many books as Tom. By setting up equations based on these relationships, it is determined that Tom read 24 books and Devi read 10 books. The calculations confirm that Devi's total is consistent with the given data. Thus, Devi read 10 books in that month.
Johnx1
Tom and Devi read 34 books in a month. Devi and Weiming read 58 books in the same month. Weiming read twice as many books as Tom. How many books did Devi read in that month?
My way of answering it:
x + x + 2x = 92
x = 23
I got stuck there.However
The book answer is 58 - 34. Then 34 -24 = 10. So Devi read 10 books, But I'm not sure how they got that answer.
Mathematics news on Phys.org
Johnx said:
x + x + 2x = 92
This would be correct if Tom and Devi read the same number of books, which is denoted by $x$ in your equation. But there is no reason to think so.
Let $t$, $d$ amd $w$ be the number of books read by Tom, Devi and Weiming, respectively. Then we can get the following equations from the problem statement.
\left\{
\begin{aligned}
t+d&=34\\
d+w&=58\\
w&=2t
\end{aligned}
\right.
Substituting $w$ from the third equation into the second one, we get
\left\{
\begin{aligned}
t+d&=34\\
2t+d&=58\\
\end{aligned}
\right.
The difference between the left-hand sides, i.e., $(2t+d)-(t+d)=t$, and from the right-hand sides the same difference is $58-34=24$. Therefore, $t=34$. Then from the first equation we get $d=34-t=34-24=10$.
Though it's good to work it out as Evgeny did there is a shortcut:
T + D = 34
2T + 2D = 68
2T + D = 58
0 + D = 10
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
