How Many Bright Spots Are Visible When Laser Shines Through Slits?
  • Thread starter Thread starter hellowmad
    Laser
The discussion centers on calculating the number of observable bright spots when a laser shines through two slits. Using the equation for diffraction, the first minimum's angular position is determined, leading to the conclusion that a total of five smaller bright spots can be observed within the central bright region. The calculations involve parameters such as wavelength, slit width, and the distance between the slits. Participants confirm the accuracy of the calculations and clarify the intent of the original question. Overall, the analysis supports the conclusion of five observable bright spots.
hellowmad
The 480 nm laser is incident on an opaque barrier with a single slit of width 8.0 x 10-5 m. A screen to view the light intensity pattern is 2.0 m behind the barrier. Then a 2nd slit of the same width is made in the barrier. The centers of the slits are 2.4 x 10-4 m apart. Approximately how many smaller bright spots are now observable within the central bright region?
d sinθ = mλ for m = 0, 1, -1, 2, -2, 3, -3, 4, -4, ….(constructive)
d sinθ = (m + 1/2 λ) for m = 0, 1, -1, 2, -2, 3, -3, 4, -4, ….(destructive)
x =λml/d
The angular position of t)he first diffraction minimum is θ≈sinθ= λ/a, and dsinθ=mλ, so m = (dsinθ) /=[d(λ/a)]/λ =d/a = (2.4 x 10-4 m)/(8.0 x 10-5 m) =3.
Since both bright and dark pots separated on both sides of central bright region, so the smaller bright spots observable within the central bright region is -2, -1, 0, 1, and 2, which leads to total 5.
I want to see if I do it right.
Thanks
Well, there's a picture here. Is that what you mean with your question ?
(PF doesn't really do approval stamps :wink: .)
hellowmad said:
Homework Statement: The 480 nm laser is incident on an opaque barrier with a single slit of width 8.0 x 10-5 m. A screen to view the light intensity pattern is 2.0 m behind the barrier. Then a 2nd slit of the same width is made in the barrier. The centers of the slits are 2.4 x 10-4 m apart. Approximately how many smaller bright spots are now observable within the central bright region?
Relevant Equations: d sinθ = mλ for m = 0, 1, -1, 2, -2, 3, -3, 4, -4, ….(constructive)
x =λml/d
Thanks
Looks right to me.
Yes it is want I mean. Thanks.
haruspex said:
Looks right to me.
thank for checking
