Demon117
- 165
- 1
Consider Herman the Fly. Herman must exist on the edges of a cube. At the start of a trial, Herman is randomly placed on one of the eight corners of a cube and poison is placed on one of the eight corners. Herman starts moving along one of the three edges. When he comes to a corner, he chooses one of the two other edges and continues. When he reaches the corner with the poison, he dies. How many edges will Herman visit before he hits the poison? Note that Herman may possibly visit zero to an infinite number of edges in a given trial.
The cube corners are labeled from 0 to 7 with 0 starting at the upper left hand corner of the front fact proceeding clockwise with corners 0, 1, 2, and 3 on the front face, and corner 4 being the upper left hand corner of the rear face and proceeding clockwise with corners 4, 5, 6, and 7 on the rear face.
Develop a simulation of Herman's travels around the cube. For each trial, print out the initial corners of Herman and the poison and all the corners Herman visits until reaching the corner with the poison. Then display the total number of corners visited by Herman in this trial and a running average of the number of corners Herman reached in all trials since the program with initiated. Then ask the user if another trial is desired.
Insufficiently commented code, poorly chosen variable or function names,. not using functions sufficiently or appropriately, using global variables when not required, nor not passing the correct information into a function, etc. will reduce one's grade. Each function requires a block comment stating your name, a single sentence (sans "ands" or "ors") stating the purpose of that function, as well as a description of the parameters (if the names are insufficient). Don't use global variables to avoid passing parameters. An acceptable solution will have at least 10 functions.
This is all that I have:
Code:
#include <iostream>
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <cmath>
using namespace std;
bool isHermanDead(int pos1,int pos2)//
if (pos1=pos2)
cout<<"Herman is Dead"<<endl;
else
cout<<"Herman is alive"<<endl;
int main()
srand( time(NULL) );
int poisonPos = rand()%10;
int hermanPos = rand()%10;
bool heDead = isHermanDead(hermanPos, poisonPos);
cout<<"The result is that "<<heDead<<endl;
system("pause");
return 0;
This is all that I have for the program so far. But apparently I have something amiss here. Does anyone know of examples out there that are similar in nature to this problem?
