How many energy requires to increase 1℃ of 1 liter of water using MICROWAVE?
In summary, the conversation discussed using a microwave to directly heat water for industrial purposes. The specific heat capacity of water was mentioned, along with the calculation for the amount of energy needed to increase the temperature of a given amount of water by 33°C. It was also noted that a microwave generator loses about 50% of its energy in the generation of microwaves and that using a resistive heater or heat pump could potentially increase efficiency. Cooling the microwave generator with the water was also suggested as a possibility.
Tamilarasan
we planning to heat water directly using microwave for industrial purpose. we need only 33deg Celsius for that I need this.
Science news on Phys.org
Welcome to PF.
It was 1 calorie per gram per deg C. Now in SI units...
Assume no phase change.
Specific heat capacity of water is about 75.375 ± 0.05 J/mol·K
The molecular weight is 18 and density is 1.00
So to increase the temperature of 18g = 18 ml of water 1°C takes 75.375 joule.
1 litre will require (1000 / 18 ) * 75.375 = 4187.5 joule per deg C.
A rise of 33°C will require 4187.5 * 33 = 138187.5 joule.
If your microwave generator delivers 500 watt that is 500 joule per second.
It will take 138187.5 / 500 = a minimum of 275 seconds to heat one litre 33°C.
The power that has to go into the water is simply the temperature difference multiplied by the thermal capacity of the water (4.2 J/(g*K)), for a temperature change of 1 K ("1℃") this is 4.2 J/g.
Other considerations: Microwaves lose about 50% of their energy in the generation of the microwaves. A simple resistive heater could save half the power and simplify the setup, and a heat pump could save even more power (but make it more complicated). Cooling the microwave generator with the water would be possible as well, and would improve the efficiency. Or cool something else if possible.
Related to How many energy requires to increase 1℃ of 1 liter of water using MICROWAVE?
1. How does the energy from a microwave affect the temperature of water?
The energy from a microwave is absorbed by the water molecules, causing them to vibrate and generate heat. This increase in heat leads to a rise in temperature of the water.
2. How much energy is required to increase the temperature of 1 liter of water by 1℃ using a microwave?
The specific heat capacity of water is 4.18 Joules per gram per degree Celsius. Therefore, to increase the temperature of 1 liter (1000 grams) of water by 1℃, it would require 4180 Joules of energy.
3. Is using a microwave more efficient in heating water compared to other methods?
Yes, using a microwave is generally more efficient in heating water compared to other methods such as stovetop or electric kettle. This is because a microwave directly heats the water molecules, whereas other methods heat the container or surrounding air first.
4. Does the type of container used affect the amount of energy needed to increase the temperature of water in a microwave?
Yes, the type of container used can affect the amount of energy needed to increase the temperature of water in a microwave. A container that is more heat-resistant, such as glass or ceramic, will require less energy compared to a container that is less heat-resistant, such as plastic.
5. Can the amount of energy required to increase the temperature of water in a microwave vary?
Yes, the amount of energy required to increase the temperature of water in a microwave can vary. Factors such as the power of the microwave, the starting temperature of the water, and the type of container used can all affect the amount of energy needed. Additionally, the efficiency of the microwave can also impact the amount of energy used.
  • Thermodynamics
