How many five card hands can you have if?
  • Thread starter mHo2
In summary, the conversation discusses different ways to count the number of different 2-card hands in a deck of cards. One approach is to use the combination formula nCr, while another is to use a specific algorithm involving picking a rank and suits for each card. The conversation also touches on the concept of inverses and the challenge of proving that two algorithms produce the same result.
mHo2
30
if three of the cards have the same face value and the other two have different face values?
nCr or (n!)/((n-r)!(r!))
So far i have this for a solution
(13C1) * (4C3) * (12C1) * (4C1) * (11C1) * (4C1)
Where xCy is a combination, and 13 or 12 or 11 C 1 is the selection of the face value, and the 4c3 or 1 is the selection of the suit(clubs, hearts, diamonds, or spades).
But i have twice the value that it should be, I'm not sure what I'm doing wrong, if someone can explain this to me intuitively that would be fantastic!
I talked to my teacher and he mentioned something about arrangement, but the explanation didn't make much sense.
Thanks
How many different 2-card hands are there in a deck of cards?
I would say
52C2 so 1326
To gain confidence in counting, we can always try to prove a one-to-one correspondence between the thing we are trying to count and the thing we actually count.
Just guessing from your product, what you are counting is the number of ways to do the following:
  1. Pick a rank*
  2. Pick 3 different suits
  3. Pick a rank different from step 1
  4. Pick a suit
  5. Pick a rank different from step 1 and step 3
  6. Pick a suit
Try explicitly writing down how to convert these choices into a 5-card hand.
*: rank is the technical term for the "face value" of a card
mHo2 said:
I would say
52C2 so 1326
Even though you are picking two cards, both different?
Oh, sorry! 52C1*51C1
  1. Pick a rank*
  4. Pick a suit
  5. Pick a rank different from step 1 and step 2
  6. Pick a suit
Brilliant! That's exactly how I'm viewing it in my head. I'm not sure where my logic fails.
I suppose with the first two steps i would choose
13C1*4C3
This would pick a rank and then for the rank that was picked, choose three of the four suits for a combination
12C1*4C1
This would pick a different rank and then choose one of four suits (same for the 3rd step).
You were right the first time. I was trying to rephrase the question to make it sound more similar to the first problem. I had a hunch if I phrased it the other way you'd get the right answer -- I was hoping you'd catch both were asking the same question.
Suppose my choices are:
  1. Jack
  2. Hearts, Spades, Clubs
  3. Three
  4. Spades
  5. Seven
  6. Diamonds
What is my hand?
When I say to explicitly write down the correspondence, I mean a direct algorithm one can use to answer questions like the above. An actual mathematical function (although not very numerical) that we can calculate with and prove things about.
The challenge is to prove:
  • Every desired hand can be produced by this algorithm
  • Two different lists of choices give two different hands
Or better yet, how to go in reverse. If my hand is
  • Queen of Spades
  • Three of Clubs
  • Eight of Hearts
  • Three of Diamonds
  • Three of Spades
Then what six choices produce this hand?
Then check to see that the two algorithms are inverses of each other. Sometimes writing down the inverse and proving this is easier than the other option of proving onto and one-to-one.
I'm having trouble differentiating between 52C1*51C1, and 52C2, why are they not the same thing?
  1. Jack
  3. Three
  4. Spades
  5. Seven
  6. Diamonds
What is my hand?
Jack of Hearts
Jack of Spades
Jack of Clubs
Thee of Spades
Seven of Diamonds
  • Queen of Spades
  • Three of Clubs
  • Eight of Hearts
  • Three of Diamonds
  • Three of Spades
I would say the 6 choices that produce this hand would be:
First rank is:
Three
The three accompanying suits are:
Diamonds, Spades, Clubs (not Hearts)
Next rank is:
Queen
Accompanying suit:
Spades
Last rank is:
Eight
Accompanying Suit:
Hearts
These seem like inverses!
Yes, they do seem like it. But you haven't actually stated an algorithm for either one yet...
(p.s. it's my bedtime. hopefully someone else will chime in if you need more help)
In that case, I'm not sure how to write an algorithm for it.
thanks for the help so far though!
Okay so as an update my problem is:
I can't differentiate between (as an example) 52C1*51C1 and 52C2
what's the intuitive difference? selection group?
EDIT:
Apparently it's due to order not mattering. My problem here is, the solution to this question, which is
13C1*4C3*12C2*4C1*4C1
I'm not sure why I can't combine both of the 'rank picking' combinations if order doesn't matter, which it shouldnt! :S
FAQ: How many five card hands can you have if?
How many five card hands can you have if you draw from a standard deck of 52 cards?
There are 2,598,960 possible five card hands that can be drawn from a standard deck of 52 cards.
How many five card hands can you have if the order of the cards does not matter?
If the order of the cards does not matter, there are 2,598,960 different combinations of five cards that can be drawn from a standard deck of 52 cards.
How many five card hands can you have if you are dealt from a deck of 52 cards and can replace any card you don't like?
If you are allowed to replace any card you don't like, there are 1,302,540,960 possible five card hands that can be created from a deck of 52 cards.
How many five card hands can you have if you are dealt from a deck of 52 cards and cannot replace any cards?
If you cannot replace any cards, there are still 2,598,960 possible five card hands that can be created from a deck of 52 cards.
How many five card hands can you have if the deck contains jokers?
If the deck contains jokers, the number of possible five card hands will depend on the number of jokers in the deck. For example, if there are two jokers in the deck, there are 2,598,960 possible five card hands. However, if there are four jokers in the deck, there are 5,176,319,320 possible five card hands.
