How Many Integers Satisfy This Inequality?
  • MHB
  • Thread starter anemone
  • Tags
    Integers
In summary, "Find the number of integers" is a mathematical problem that asks you to determine the total count of whole numbers within a given range or set. To find the number of integers in a given range, you can first determine the smallest and largest whole numbers within that range. Then, you can subtract the smallest number from the largest number and add 1 to get the total count of integers. Integers are whole numbers that do not have a decimal or fractional component, while real numbers include both integers and numbers with decimal points or fractions. Yes, negative numbers can be considered integers as they are included in the definition of integers. Zero is also considered an integer as it is a whole number.
anemone
MHB
POTW Director
3,883
115
How many integers satisfy the following relation?
\(\displaystyle |||x+9|-18|-98| \le 82\)
Mathematics news on Phys.org
if we put x + 9 >= 0 we get
- 82 <= | x- 9 | - 98 <= 82
so 165 solutions as |x -9| - 98 can be atleast -98
similarly if we put | x+ 9| <= 0 so 165 solutions
so 330 solutions
kaliprasad said:
so 330 solutions
BUT...I got 332.
anemone said:
BUT...I got 332.
I would like to have a look at the correct solution
My solution:
We have two cases to consider here, one is when $x+9\ge 0$ and the other is when $x+9< 0$.If $x+9\ge 0$ (i.e. $x \ge -9$), then the inequality becomes
\(\displaystyle ||x+9-18|-98| \le 82\)
\(\displaystyle ||x-9|-98| \le 82\)
i.ii.
Now, let $x-9\ge 0$ (i.e. $x \ge 9$), we haveNow, let $x-9< 0$ (i.e. $x \ge 9$), we have
\(\displaystyle |x-9-98| \le 82\)
\(\displaystyle |x-107| \le 82\)
\(\displaystyle -82 \le x-107 \le 82\)
\(\displaystyle 25 \le x \le 189\)
\(\displaystyle |-(x-9)-98| \le 82\)
\(\displaystyle |-x-89| \le 82\)
\(\displaystyle -82 \le -x-89 \le 82\)
\(\displaystyle -171\le x \le -7\)
The number of integers that satisfy the aforementioned relation is thus $165$.
The number of integers that satisfy the aforementioned relation in this particular case is thus $2$.
But if $x+9< 0$ (i.e. $x<-9$), then the inequality becomes
\(\displaystyle ||-x-9-18|-98| \le 82\)
\(\displaystyle ||-x-27|-98| \le 82\)
i.ii.
Now, let $-x-27\ge 0$, we haveNow, let $-x-27< 0$, we have
\(\displaystyle |-x-27-98| \le 82\)
\(\displaystyle |-x-125| \le 82\)
\(\displaystyle -207 \le x \le -43\)
\(\displaystyle |-(-x-27)-98| \le 82\)
\(\displaystyle |x-71| \le 82\)
\(\displaystyle -11\le x \le 153\)
The number of integers that satisfy the aforementioned relation is thus $165$.The number of integers that satisfy the aforementioned relation in this particular case is thus $2$.
Therefore, the total number of integers satisfy the relation \(\displaystyle |||x+9|-18|-98| \le 82\) is $165+3+165+2=335$.
Hey kaliprasad, I'm sorry because according to my previous reply, I told you the answer that I've gotten was 332, which isn't the correct answer. :eek:
FAQ: How Many Integers Satisfy This Inequality?
What does "Find the number of integers" mean?
How do I find the number of integers in a given range?
What is the difference between integers and real numbers?
Integers are whole numbers that do not have a decimal or fractional component. Real numbers, on the other hand, include both integers and numbers with decimal points or fractions.
Can negative numbers be considered integers?
Yes, negative numbers can be considered integers. Integers include all whole numbers, including negative numbers, positive numbers, and zero.
Is zero considered an integer?
Yes, zero is considered an integer. Integers include all whole numbers, including negative numbers, positive numbers, and zero.
