How many marbles in a cylinder if
  • Thread starter LearninDaMath
  • Tags
    Cylinder
The units of the final result would also be in meters, since we are dealing with volume, which has units of length cubed.
LearninDaMath
295
Suppose there are 1000 marbles/meter^3
And I have a cylinder of [itex]\pi[/itex]r^2(h), where radius is 2 meters and height is 5 meters.
How many marbles can the cylinder hold?
Do I have to somehow convert volume of the form [itex]\pi[/itex]r^2(h) to volume of the form meters^3? If so, how can this be done? For example, if I have a cylinder of dimensions [itex]\pi[/itex]3^2(10), how can I describe this volume in terms of meters^3?
This is not an assigned homework question, just self study.
(meters) times (meters) times (meters) is meters3 .
Yes, I know what the exponent of 3 means. My question is in regard to a cylinder.For instance, when I compute πr^2(h) when r=3 and h=10, I get 282.74... but what does that actually mean? Is it 282.74 m^3? Or do I need to do some further converting?
This is a very difficult and non-trivial problem; only recently have some problems of this type been solved. The difficulty is that volumes alone do not tell the whole story. You can have two different shaped containers having the same volume, but one can hold a significantly different number of marbles than the other. You have to pack the marbles together, so how the marbles can be made to fit partially into the spaces between other marbles will matter a lot.
For more material on this, Google "sphere-packing problem" and obtain numerous links, such as
http://en.wikipedia.org/wiki/Sphere_packing or
http://mathworld.wolfram.com/SpherePacking.html or
http://www.maa.org/devlin/devlin_9_98.html
Other links with much longer url's give pdf files of some of the recent research on the issue; they are all difficult to read and involve advanced mathematics.
RGV
RGV
Okay thanks Ray, so given that a problem of this kind is very difficult and ignoring any attempt at finding the number of marbles that can fit in the cylinder, what if I just want to know:
How many cubic meters are exist in a cylinder of a given dimension? For instance, if I have a cylinder of πr^2(h) when r=3 and h=10, I get 282.74... but what does that actually mean? What unit of volume is the number 282.74? Is it 282.74 m^3? Or is it some other unit that I might be unaware of? Do I need to do some further converting in order to represent it in terms of meters^3?
The units of volume here would be cubic meters, or m3. There is also a somewhat obscure unit in the metric system - a stere. A stere is one cubic meter.
It is so obscure that's the first time I hear about it
Well what units are "r" and "h" in?
Out with cubic centimeters! In with nanosteres!
Gee, I thought you guys in Europe would be well-versed in all things metric. I'm shocked!:eek:
Give me the good ol' English system, with such handy units as furlongs/fortnight, etc.
Cubic meters is something I hear about (and use) quite often, but stere... In Poland we sometimes call it "kubik" or "metr kubiczny". Funny thing is "kubik" (noun) and "kubiczny" (adjective) are obvious copies of "cube" and "cubic" - but they are not used in Polish in other contexts. In general "cubic" is "sześcienny" (adjective, made from "sześcian" - a cube).
At the same time steradian I know.
thanks for the feedback and i enjoyed reading the rest of the light hearted dialogue. appreciate your help.
Related to How many marbles in a cylinder if
1. How do you calculate the volume of a cylinder?
The volume of a cylinder is calculated by multiplying the area of the base (πr²) by the height (h), where r is the radius of the base and h is the height of the cylinder.
2. What is the formula for finding the number of marbles in a cylinder?
The formula for finding the number of marbles in a cylinder is (V/m) x h, where V is the volume of the cylinder, m is the volume of one marble, and h is the height of the cylinder.
3. How do you measure the diameter of a marble?
The diameter of a marble can be measured using a ruler or caliper. Place the marble on a flat surface and use the ruler or caliper to measure the distance across the widest part of the marble.
4. Can the number of marbles in a cylinder be calculated if the diameter of the marbles is not given?
Yes, the number of marbles in a cylinder can still be calculated if the diameter of the marbles is not given. However, an estimation of the diameter or an average diameter of the marbles will be needed for the calculation.
5. Are there any other factors that might affect the number of marbles in a cylinder?
Yes, there are other factors that might affect the number of marbles in a cylinder. These include the shape of the marbles (e.g. spherical or irregular), the packing density of the marbles, and the accuracy of the measurements used.
  • General Math
  • Thermodynamics
  • Mechanical Engineering
