MHB How Many Numbers Less Than 1000 Divisible by 5 Are Formed Using Unique Digits?
  • Thread starter Thread starter mathdad
    Numbers
The total number of unique-digit numbers less than 1000 that are divisible by 5 is 154. Numbers must end in either 0 or 5, with specific calculations for one-digit, two-digit, and three-digit numbers. For one-digit, only the number 5 qualifies. Two-digit numbers yield 17 combinations, while three-digit numbers provide 136 combinations. The calculation confirms that 154 is accurate if 0 is excluded from the count.
mathdad
The total number of numbers less than 1000 and divisible by 5 formed with 0,1,2,...9 such that each digit does not occur more than once in each number is what?
Solution:Divisible by 5 ==> number ending in 0 or 5.
Number of ways with no repeated digit:
[0, 9]---> ends in 5 = 1 way (only 5 here).
[10,99]
————> ends in 0 = 9 ways
————> ends in 5 = 8 ways (cannot use 55 )
————> 9 + 8 = 17 ways for two digit numbers in total
[100,999]
————> ends in 0 {once 0 is selected you are left with 9 digits)
{ 9 ways to select the 1st digit and 7 ways to select the 2nd digit}
9 x 8 = 72 ways
————> ends in 5 (cannot start with 0 but can use 0 for 2nd digit)
{8 ways to select 1st digit and 8 ways to select 2nd digit)
8 x 8 = 64 ways
————> 72 + 64 = 136 ways for three digit numbers in total
Number of numbers = 1 + 17 + 136 = 154 numbers
Is this right?
Mathematics news on Phys.org
Yes, this is right if you don't count 0.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
