How many one-to-one functions f are possible?
  • Thread starter snipekiller
  • Tags
    Functions
In summary, to find the number of one-to-one functions f: A → B, where |A| = n and |B| = m with n ≤ m, we can use the fact that for |A| = |B| = m, the number of different bijections f: A → B is m!. Therefore, the number of one-to-one functions is also m!.
snipekiller
Suppose that |A| = n and |B| = m with n ≤ m. How many one-to-one functions f are possible with f: A → B?
If |A| = |B| = m how many different bijections f: A → B are possible?
Answer: m!
I really do not know how to start off the question. If someone can help me get started into this equation that would be great!
The relevant equation I did manage to get. but I do not know how to solve the problem when the size of A is not equal to the size of B.
Well, you know f is a bijection into the subset of B given by f(A). Now you just have to figure out the number of ways to choose a subset of B of size |A|.
Answer: m!
Do you know how to compute the total number of functions from A to B? If you can do that, you can use the same type of reasoning for this problem, remembering that as you construct a function it must be 1-1.
FAQ: How many one-to-one functions f are possible?
What is a one-to-one function?
A one-to-one function is a mathematical concept in which each input (or element in the domain) has a unique output (or element in the range). In other words, no two inputs can have the same output. This is also known as an injective function.
How do you determine the number of possible one-to-one functions?
The number of possible one-to-one functions depends on the size of the domain and range. For a domain of size n and a range of size m, the number of possible one-to-one functions is given by m!/(m-n)!, where ! represents the factorial function.
Can a one-to-one function have a larger range than domain?
Yes, a one-to-one function can have a larger range than domain. This means that some elements in the range will not have a corresponding element in the domain, but all elements in the domain will have a unique element in the range.
Is a one-to-one function the same as a bijection?
Yes, a one-to-one function is the same as a bijection. Both terms refer to a function in which each input has a unique output and vice versa.
Are all one-to-one functions also onto functions?
No, not all one-to-one functions are onto functions. An onto function, also known as a surjective function, is one in which every element in the range has a corresponding element in the domain. A one-to-one function can have a larger range than domain, meaning not all elements in the range will have a corresponding element in the domain.
