How Many Ordered Triples (a, b, c) Satisfy Given LCM Conditions?
  • MHB
  • Thread starter juantheron
In summary, the possible combinations of powers of 2 and 3 in b and c respectively are (3,0), (3,1), (3,2), (3,3), (0,3), (1,3), (2,3) for b and (2,0), (2,1), (2,2), (1,2), (0,2) for c. This results in a total of 35 possible pairs for (a,b,c).
juantheron
247
If $\bf{L.C.M}$ of $(a,b)$ is $432,$ and $\bf{L.C.M}$ of $(b,c)$ is $72,$ and $\bf{L.C.M}$ of $(c,a)$ is $432.$
Then the number of ordered pairs $(a,b,c)$ is
My Trail Solution:: First we will factorise in prime factor form.
$\bf{L.C.M}$ of $(a,b)$ is $ = 432 = 2^4 \times 3^3$
Similarly $\bf{L.C.M}$ of $(b,c)$ is $ = 72 = 2^3 \times 3^2$
Similarly $\bf{L.C.M}$ of $(c,a)$ is $ = 432 = 2^4 \times 3^3$
Now Let we assume that $a = 2^l\cdot 3^m$
and Similarly $b = 2^p\cdot 3^q$
and Similarly $c = 2^x\cdot 3^y$,
Now How can i solve after that
Help Required.
Thanks.
Mathematics news on Phys.org
Help Required.
Thanks.
This has more than one solution and we can approach as
First find power of 2
Higest from LCM of (b,c) = 3 so so b cannot have power > 3 and c cannot power > 3
So power or 2 in a = 4
Now in b and c can be (3,0), (3,1), (3,2), (3.3), (0,3),(1,3),(2,3) as these combinations given power 3
Similarly you can find the power of 3
In a = 3 an in bc = (2,0),(2,1)(2,2),(1,2),(0,2)
So a = 432 and for bc there are 35 sets
for example one is (2^3*3^2,1)
Help Required.
Thanks.
Enumerate.
Smartly.
What are the possible combinations of powers of 2 and 3 in b respectively c due to $\text{LCM}(b,c)=2^3 \times 3^2$?
In each case, what are the possible powers of 2 and 3 in a?
FAQ: How Many Ordered Triples (a, b, c) Satisfy Given LCM Conditions?
How do you calculate the number of ordered pairs (a,b,c)?
The number of ordered pairs (a,b,c) can be calculated using the formula n^3, where n is the number of elements in the set. For example, if the set contains 3 elements, the number of ordered pairs would be 3^3 = 27.
How does the number of ordered pairs (a,b,c) change with different sets?
The number of ordered pairs (a,b,c) will vary depending on the number of elements in the set. As the number of elements increases, the number of ordered pairs will also increase.
Can the number of ordered pairs (a,b,c) be negative?
No, the number of ordered pairs (a,b,c) cannot be negative. It represents the total number of unique combinations that can be formed using the elements in the set.
How is the number of ordered pairs (a,b,c) related to permutations and combinations?
The number of ordered pairs (a,b,c) is related to permutations and combinations in that it represents the total number of permutations with repetition. This means that the order of the elements matters and there can be repetition of elements in the ordered pairs.
Can the number of ordered pairs (a,b,c) be greater than the number of elements in the set?
Yes, the number of ordered pairs (a,b,c) can be greater than the number of elements in the set. This is because ordered pairs can contain repeated elements, while the set only contains unique elements.
