How many people can be on the raft?
In summary, the question of how many people can be on the raft depends on various factors, including the size and weight capacity of the raft, the weight of the individuals, and safety regulations. It is crucial to consider these aspects to ensure stability and prevent capsizing while maximizing the number of occupants safely.
lgeorge
A raft is made of 13 logs lashed together. Each is 45 cm in diameter and has a length of 6.0 m. How many people can the raft hold before they start getting their feet wet, assuming the average person has a mass of 68 kg? Do not neglect the weight of the logs. Assume the specific gravity of wood is 0.60.
W = mg
Fb=(density)Vg
V = (pi)r^2(h)
density = mV
First I calculated the volume of all of the logs...
V = 13((pi)(.225)^2(g)) = 3.94
Then wanted the mass of the logs
m = density(Volume)
density = .6(997)
m = 2356
Then calculated buoyant force...
Fb = (997)(3.94)(9.8) = 3928
Then set this equal to weight of people and logs
38496 = ((number of people)(68) + 2356)(9.8)
n=23.12
23 people is wrong
Where in your calculation did you use the length of the logs? Also what's the g in the equation for V?
Sorry that g is supposed to be a 6
It's hard to tell what you're doing when you put down numbers without units.
Is this the volume of all the logs together?
lgeorge said:
density = mV
density = .6(997)
What's the definition of density?
If V = 3.94 (units TBA), what does V stand for in the equation above and how did it become 997? Where did this 997 come from anyway?
Re check your calculation for V, I think there's an error.
Likes SammyS
Very true I need to work with my units more because I found my error once I went through the calculation slower with units! Thank you so much!
Likes docnet
I strongly suggest never putting in numbers before you arrive at a final expression for what you want to compute. It will make your work clearer as well as make it easier to check for errors and to understand the functional behaviour of your result.
If you insist on putting in numbers, never do so without attaching the appropriate units!
Likes pines-demon
For a list of the benefits of working algebraically (any I missed?) see https://www.physicsforums.com/insights/frequently-made-errors-equation-handling/
I agree with the points, but the precision example is a bit unfortunate. The required ##\Delta T## is part of the input and has two significant digits at best. I’d probably deduct credit for anyone answering with more than two significant digits.
Good point, but of course it was taken from an actual thread. I'll change it to 10.00 seconds.
Then you run into other issues limiting accuracy, such as the Earth not being perfectly spherical, mountains, and how accurately you could actually measure the period. I am of course playing the devil's advocate here ... but I feel there should be possible to define a better example.
FAQ: How many people can be on the raft?
1. What is the context of the raft problem?
The raft problem often refers to a thought experiment or a scenario used in discussions of survival, resource allocation, or ethical dilemmas. It typically involves a limited number of people and a raft that can only support a certain weight or number of individuals, raising questions about who should be allowed on the raft based on various criteria.
2. How is the maximum number of people determined for the raft?
The maximum number of people that can be on the raft is determined by factors such as the raft's size, weight capacity, and stability. Additionally, considerations of safety, resource availability, and the physical condition of the individuals involved also play a critical role in making this determination.
3. What ethical considerations come into play when deciding who can be on the raft?
Ethical considerations include fairness, the value of individual lives, the potential for future contributions to society, and the concept of utilitarianism, where the focus is on maximizing overall well-being. Decisions may involve prioritizing certain individuals based on age, health, skills, or relationships.
4. Are there any real-life applications of the raft problem?
Yes, the raft problem has real-life applications in various fields, including emergency management, disaster response, and humanitarian efforts. It serves as a framework for discussing resource allocation in crises, such as during natural disasters or in situations of overcrowding and limited resources.
5. Can the raft problem be solved mathematically?
While the raft problem is often framed as a philosophical or ethical dilemma, some aspects can be approached mathematically, particularly in terms of optimizing the number of individuals based on constraints like weight limits or resource availability. However, the subjective nature of ethical decision-making complicates purely mathematical solutions.
