How many positive integer solutions satisfy this equation?
More formally, ##43## divides ##xy##, hence ##43## divides ##x## or ##43## divides ##y##. Similarly, ##47## divides ##x## or ##47## divides ##y##.This gives us four possibilities, which reduces to two by the symmetry of ##x## and ##y##:a) ##2021## divides ##x## and ##47## divides ##y##; or,b) ##2021## divides ##y## and ##43## divides ##x##.In case a), we can write ##x = 2021k## and ##y = 47m##, which leads to a quadratic in ##k##. Case b) is similar.
  • #36
OmCheeto said:
62?
62 is the number of integer solutions. But the question asked for the number of positive integer solutions.
  • #37
songoku said:
Yes, I know how to graph hyperbola from general equation:
$$\frac{(x-h)^2}{a^2}-\frac{(y-k)^2}{b^2}=1$$
You get different kinds of equations depending on how the hyperbola is rotated. For example xy=1 is the equation for a hyperbola. It's easy to tell how many integer solutions that one has.
Your equation is also a hyperbola. If you write the equation in the appropriate form you'll find the asymptotes and also the number of integer solutions.
songoku said:
If by degree-2 equation you mean quadratic equation, then yes I can solve it using factorization, quadratic formula or completing square.
You also got a quadratic equation. It has two variables, so complete the rectangle instead of completing the square.
Likes songoku
  • #38
Thank you very much for the help and explanation Delta2, BvU, anuttarasammyak, WWGD, Hall, Prof B, OmCheeto, PeroK
Likes Hall and Delta2
  • #39
We didn't see a lot of your work in this thread, it must be said!
  • #40
songoku said:
Hello @Hall :smile:
I got the answer. Thank you
Yup - don't tell us you got the answe, tell us the answer you got!
  • #41
$$\frac{1}{x}+\frac{1}{y}+\frac{1}{xy}=\frac{1}{2021}$$
$$\frac{x+y+1}{xy}=\frac{1}{2021}$$
$$2021x+2021y+2021=xy$$
$$2021=xy-2021(x+y)$$
$$2021=(x-2021)(y-2021)-2021^2$$
$$(x-2021)(y-2021)=2021+2021^2$$
$$(x-2021)(y-2021)=2021 \times 2022$$
Let: ##x-2021=a## , then ##y-2021=\frac{2021 \times 2022}{a}=\frac{43 \times 47 \times 2 \times 3 \times 337}{a}##
Since ##a## is integer then for ##y## to be integer, ##a## must be combination of factor of 43, 47, 2, 3, and 337.
Each number has 2 factors so the possible combinations for ##a=2^5=32##
Likes Prof B, Delta2, epenguin and 2 others
  • #42
There's some work left to do. If a is positive then x and y are greater than 2021 so x and y are positive. You get 32 solutions that way. What if a is negative? Why don't you get any more solutions that way?
Likes songoku
  • #43
Obviously from post #35 [tex]x,y=2021-2^l 3^m 43^n 47^r 337^s, 2021-2^{1-l} 3^{1-m} 43^{1-n} 47^{1-r} 337^{1-s}
[/tex]
where
[tex]l,m,n,r,s=\{0,1\}[/tex] Another 32 solutions.
[EDIT] Now I find (x,y)=(0,-1),(-1,0) should be excluded thanks to @PeroK #44.
Likes songoku
  • #44
First, assuming ##a, b## are positive. We have ##x = a + 2021, \ y = b + 2021## and ##ab = 2021(2022)##.
We have the solution ##a = 2021, b = 2022## (and vice versa). Otherwise, ##a > 2022, b < 2021## or vice versa.
If we take the negative solutions ##-a, -b##, then the first two solutions are invalid, as either ##x## or ##y## is zero. And the original equation involved reciprocals. Otherwise, we have ##x > 0, y < 0## or vice versa. So, there are no more positive solutions.
There are, however, ##30 = 15 \times 2## further solutions with one of ##x, y## negative and the other positive.
Likes songoku and anuttarasammyak
