MHB How many possible lunch special combinations can be ordered
  • Thread starter Thread starter greprep
    Combinations
To determine the total number of lunch special combinations at Deb's Deli, customers can choose either a sandwich with a salad or a sandwich with a soup. There are 5 sandwich options, 4 salad options, and 3 soup options available. The quickest way to calculate the combinations is to use the fundamental counting principle, which involves multiplying the number of sandwich choices by the total number of item choices (salad and soup combined). This results in the equation N = 5(4 + 3), leading to a total of 35 possible combinations. Understanding this approach can help clarify combination questions for GRE preparation.
greprep
Hi All, I'm studying for the GRE, and really struggling with combination questions for some reason. I'm posting here quite a bit, but just wanted to say thank you so much for your help.
What would be the fastest way to solve the following?
"At Deb's Deli, a customer may choose either a sandwich and a salad or a sandwich and a soup for the lunch special. There are 5 choices of sandwich, 4 choices of salad, and 3 choices of soup. How many possible lunch special combinations can be ordered"
Mathematics news on Phys.org
One way would be to compute the number of possible sandwich/salad combinations are possible, then compute the number of sandwich/soup combinations are possible, and then add the two to get the total. Or, you could do it in one pass by looking at it as a sandwich/item problem, where you have 5 choices for sandwich and 7 choices for item (salad or soup) and apply the fundamental counting principle.
What do you get?
Would it then just be 5x4x3, according to the fundamental counting principal?
No, not quite...you have 5 sandwich options, and then for the second option, you have 3 + 4 options:
$$N=5(4+3)=\,?$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
