How many seconds does it take for a car to deliver 4299.1N?
  • Thread starter IDKPhysics101
  • Tags
    Car Seconds
In summary, the formula for calculating the time it takes for a car to deliver a force of 4299.1N is time = force/mass x acceleration, but it is only applicable if the car is accelerating at a constant rate. The mass of the car can be determined by weighing it or finding the manufacturer's specifications, while the acceleration can be measured using a speedometer or by calculating the change in velocity over time. 4299.1N is a realistic force for a car to deliver, but other factors such as road conditions, car weight, and engine efficiency can affect the time it takes. The accuracy of the calculation using the given formula depends on the accuracy of the measurements and the assumption of constant acceleration, with external
IDKPhysics101
31
A 765.1 kg car accelerates from rest to 20.9 m/s. If the engine can deliver 4299.1 N of force, how many seconds does it take the car to do this?
v = a * t;
we know a = f/m;
t = m * v/f
t=m*v/f
t=765.1*20.9/4299.1
t=3.71seconds?
Yes, that's right.
awesome, thanks alot! i promote you and rock freak to be our class's teacher
Related to How many seconds does it take for a car to deliver 4299.1N?
1. What is the formula for calculating the time it takes for a car to deliver a force of 4299.1N?
The formula for calculating time is time = force/mass x acceleration. However, this formula is only applicable if the car is accelerating at a constant rate. If the car is not accelerating, the formula would not be applicable.
2. How do I determine the mass and acceleration of the car?
The mass of the car can be determined by weighing it or finding the manufacturer's specifications. The acceleration can be measured using a speedometer or by calculating the change in velocity over time using the equation acceleration = (final velocity - initial velocity)/time.
3. Is 4299.1N a realistic force for a car to deliver?
It is not uncommon for cars to deliver forces in the thousands of Newtons, especially during acceleration or braking. However, the specific value of 4299.1N would depend on the specific car and its capabilities.
4. Can other factors affect the time it takes for a car to deliver 4299.1N?
Yes, factors such as the condition of the road, the weight of the car, and the efficiency of the engine can all affect the time it takes for a car to deliver a force of 4299.1N. Other external factors such as wind resistance and incline of the road can also play a role.
5. How accurate is the calculation of time using the given formula?
The accuracy of the calculation depends on the accuracy of the measurements used for force, mass, and acceleration. In addition, the assumption that the car is accelerating at a constant rate also affects the accuracy of the calculation. Other factors such as air resistance and friction can also affect the accuracy of the calculation.
