How many sets of 6 can be made from a set of 12
  • Thread starter Vector1962
  • Tags
    Set Sets
In summary: C" instead of "P". If we do not count different orderings of the balls in the bag, then there is only one way to choose 3 white and 3 black balls. That does not seem to be what you want. If you want to consider different orderings of the balls in the bag, then you are not dealing with combinations. Even if you consider the white balls to be identical, you still have 3 black balls that can be ordered in 3! ways. (3! is 3*2*1.) If the black balls are not identical, then you have 3! ways to choose them as well.
Vector1962
61
[/B]
A bag has a total of 12 balls, 3 of which are black. If you select 6 balls from the bag. a) How many sets of 6 can be made? b) How many of the sets of 6 contain 3 black balls? c) What is the probability of selecting a set of 6 that contains 3 black balls?
NPR
NCR
[/B]
Part a) I believe 12C6 gives the total of sets of 6 = 924
Part b) I believe 9C6 gives the total of sets of 6 of white balls only so (12C6) - (9C6) = sets that have 3 black?
Part c) [ 12C6 - 9C6 ] / 12C6 ?
Part a: You haven't said if the 3 black balls are considered identical. Your calculations assume that they are all different. The same goes for the other (non-black) balls. Your answer may be right, but it may not be.
Part b: For a quick sanity check, (12C6) - (9C6) = 924-84=840. If that was correct, you would be almost certain (see Part c answer) to pick all 3 black balls even though they are only 1/4th of the balls. So half of the picks are black even though they are only 1/4th of the 12. That seems wrong.
Part c: (924-84)/924 = 0.90909... This seems too high since only 1/4th of the balls are black and this says you are very likely to select 3 black in 6.
Vector1962 said:
[/B]
NPR
NCR
[/B]
The set of all choices minus the set of choices of only white balls leaves the set of all choices containing at least one black ball. Not what you want.
In terms of combinations, it seems there is only 1 combination that has 3 black balls and 3 white balls?
Since you only have 3 black balls, I'd agree about there only being one choice there. But how about the white balls? You have more than 3 to choose from.
In terms of combinations, if I have 3 black balls and 3 white balls, that leaves 6 white balls which can be split into 2 combinations of 3 white balls. Which, in turn, can be paired with the 3 black balls. So, 3 possible sets of those... but aren't those 3 sets all the same --> 3 black and 3 white?
For part b: Specify a specific order of picking 3 black and 3 white balls and figure out how many ways that specific order can occur. Then multiply that by the number of ways 3 black and 3 white balls can be ordered in the 6 balls.
As always, be careful about double counting the same thing.
Sorry, not even a clue what you mean. If I specify BWBWBW as a specific order there is only 1 way that occurs. Are you asking me to find how many ways can 3 black balls and 3 white balls be arranged?
You are getting off the beam here. Of course, if you pick 3 white balls and 3 black balls you wind up with 3 black and 3 white. Number each ball and call them ##B_1, B_2, B_3, W_1, W_2, W_3, W_4, W_5, W_6,W_7, W_8, W_9##. Now how many ways to choose 3 white and 3 black?
EDIT: CORRECTION. This post is wrong.
Your calculated answers like part a 12C6 have been assuming that all the balls are different regardless of their color. In other words, in your calculations B1WB2WB3W is not the same as B2WB1WB3W.
That is why I asked in post #2 if the black balls should be considered identical or not. If you consider them to be identical, then you have to take that into account in all your answers. Your answer in part a would be wrong. You need to divide by the number of different ways balls that you consider identical could be swapped around.
This is going off track. Combinations, like ##_{12}C_6##, do NOT count different orderings as different. And I think questions a) and b) are steps on the way to answering c) which is a question about probability. If the balls are indistinguishable then you could correctly answer a) as "There are 4 ways, no black, 1 black, 2 black or 3 black". That's obvious and it's useless for calculating probability since those 4 cases aren't equally probable. I think any debate about 'identical' or not is confusing the issue.
Oh! Sorry. right! I stand corrected. They do not count different orderings as different. I will correct my post.
Well, if I have a set of n items then the number of permutations of n items where p items are identical and q items are identical and r items are identical and so on is given by n! / (p! q! r!...) . At least that's what I found in a statistics book. So, if I have a set of 6 balls and 3 of them are black and 3 of them are white then the number of distinct permutations is 6! / (3! 3!) = 20. so if there are 20 sets possible containing 3 white balls and 3 black balls. This leads to 20 / 12C6 as the probability of getting one of those sets from the 12C6 possible sets? --> 20/924 = 0.02
As long as I'm guessing, The number of ways to arrange 3 black balls from a set of 3 black balls is 3C3 = 1. The number of ways to select 3 white balls from a set of 9 white balls 9C3 = 84. The fundamental counting principle indicates the number of ways to pair these 2 sets together is to multiply the number of elements in each set together, so 84 * 1 = 84. The total number of distinct sets is 12C6 = 984 hence, the probability of selecting 1 of the 84 "good sets" from the total possible sets is 84/984 = 0.08 ? --> for some reason this one sound right? Even if it's not, I appreciate the time you both devoted to help make the approach to this type of problem more clear.
You've got it. This version is correct. Except that ##_{12}C_9=924##. It's not clear to me what the other approach is all about with counting some kind of permutations in the numerator and combinations in the denominator. If you want proof, do an experiment with real balls. This approach will give you the correct probability of drawing 3 white and 3 black.
The permutation 'gibberish' is me reading a statistics book, grasping at some straws trying to make some sense of all this. In the text it mentions "repeated" items and thought I was getting close. I realize the approach should be "Read, Understand, Do". Sometimes I just have to put something down on 'paper' and see if it makes sense. To be truthful, this counting stuff get's confusing. Again, thanks for the help.
Here's an alternative way to do part c). Maybe this will be gibberish as well!
First, if you pick 6 balls, what is the probability the first 3 are black?
That's ##(\frac{3}{12})(\frac{2}{11})(\frac{1}{10}) = \frac{1}{220}##
Next, how many ways could you get all three black?
It could be the first three, numbers 1,2 and 4 etc. That's ##\binom{6}{3} =20##.
Are all these possibilities equally likely? is it just as likely to get numbers 1,2,3 black as any other three numbers? You may need to think about this, but the answer is yes.
So, the probability of getting all three black is ##\frac{20}{220} = \frac{1}{11}##.
This agrees with your revised answer of ##\frac{84}{924}##.
Does this more intuitive approach help?
I'm afraid it would have not have occurred to me to approach the problem this way. For some reason, needed to think in terms of sets and I needed a set of 6. My efforts were directed on finding how to generate sets of 6. To start by picking 3 black 'first' would not have crossed my mind. Actually, I'm not sure why I would find the probability of picking the 'first' 3 black? Your solution amounts to the probability of picking 3 black balls times the number of distinct ways 3 white and 3 black can be arranged -> n! / (p! q! r!...) ?
My solution was to realize that getting all 3 black balls can be done in 20 equally likely ways. Then you just need to calculate the probability of one of those ways and multiply by 20.
I like to do these counting problems two different ways and check I get the same answer.
Related to How many sets of 6 can be made from a set of 12
What is the formula for calculating the number of sets of 6 that can be made from a set of 12?
The formula for calculating the number of sets of 6 that can be made from a set of 12 is 12 choose 6, which is written as 12C6. This is equal to 924 possible sets.
Can the number of sets of 6 be greater than the total number in the set?
No, the number of sets of 6 cannot be greater than the total number in the set. This is because each set of 6 can only contain a maximum of 6 items, so there cannot be more sets than items in the original set.
What is the difference between combinations and permutations?
Combinations and permutations are both ways to arrange a set of objects, but permutations take into account the order of the objects, while combinations do not. In this case, the number of sets of 6 is a combination because the order of the items does not matter.
How would the number of sets change if the set size or desired set size were to change?
The number of sets would change depending on the set size and desired set size. For example, if the set size were to increase to 15 and the desired set size remained at 6, the number of possible sets would increase to 5005. Similarly, if the desired set size were to increase to 8 and the set size remained at 12, the number of possible sets would decrease to 495.
Can this formula be used for sets of any size and desired set size?
Yes, this formula can be used for sets of any size and desired set size. The formula is n choose r, where n represents the original set size and r represents the desired set size. As long as the desired set size is less than or equal to the original set size, this formula can be used to calculate the number of possible sets.
