How many spheres are in a tetrahedral stack and what is its height?
  • MHB
  • Thread starter MarkFL
  • Tags
    Spheres
In summary, the stack of spheres has a total of $N=6$ spheres. The height of the stack is a function of the number of spheres in the stack and the diameter of the spheres.
MarkFL
MHB
13,288
Consider a tetrahedral stack of spheres as in this image:
Suppose there is a stack consisting of $n$ layers, and the spheres all have diameter $d$.
Showing your work:
a) Compute the number $N$ of spheres in the stack as a function of $n$. Then, express $N$ as a binomial coefficient.
b) Compute the height $h$ of the stack as a function of $d$ and $n$.
Mathematics news on Phys.org
b)My attempt on '\(\displaystyle b\)':
Tetrahedron formed is of side \(\displaystyle (n-1).d\) .The vertex \(\displaystyle A\)(center of upper sphere),centroid of triangle formed by lower spheres \(\displaystyle G\) and one of lower vertices B(or C or D) forms right angled triangle.
\(\displaystyle \begin{align*}\text{AG}=\text{height}&=\sqrt{(\text{AB})^2-(\text{BG})^2}\\&=\sqrt{(n-1)^{2}.d^{2}-\frac{(n-1)^{2}.{d}^2}{3}}\\&=\sqrt{\frac{2}{3}}(n-1)d\end{align*}\)
mathworker said:
b)My attempt on 'b':
Tetrahedron formed is of side \(\displaystyle (n-1).d\) .The vertex A(center of upper sphere),centroid of triangle formed by lower spheres G and one of lower vertices B(or C or D) forms right angled triangle.
You are close...but you have left out something.
\(\displaystyle \sqrt{\frac{2}{3}}(n-1)d+d\)?(adding the upper and lower part of spheres)
Yes, that is correct...well done! (Sun)
a)counting from each layer,
total number of spheres is,
\(\displaystyle \sum_{n=1}^n \frac{n(n+1)}{2}=\frac{n(n+1)(n+2)}{6}=\binom{n+2}{3} \)
I would avoid using the same variable for both the index of summation and the upper limit; I would write instead:
\(\displaystyle \sum_{k=1}^n \frac{k(k+1)}{2}=\frac{n(n+1)(n+2)}{6}=\binom{n+2}{3} \)
May I ask how you determined the partial sum? (Wink)
\(\displaystyle \begin{align*}\sum\frac{n(n+1)}{2}&=\frac{1}{2}(\sum_n^2)+\sum n)\\&=\frac{1}{2}\left(\left(\frac{(n(n+1)(2n+1)}{6}\right)+\left(\frac{n(n+1)}{2}\right)\right)\\&=\frac{n(n+1)}{4}.\left(\frac{2n+1}{3}+1\right)\\&=\frac{n(n+1)(n+2)}{6}\end{align*}\)
Here is my solution:
a) First, we want to compute the number of spheres $S_k$ in the $k$ layer (where $1\le k\le n$), counting from the top. Each layer is a triangular grid of spheres with $k$ rows, and we may use the difference equation:
\(\displaystyle S_{j}-S_{j-1}=j\) where \(\displaystyle S_{1}=1\) and \(\displaystyle 1\le j\le k\)
The homogeneous solution is:
\(\displaystyle h_j=c_1\)
and we should then expect to find a particular solution of the form:
\(\displaystyle p_j=Aj^2+Bj\)
Substituting this particular solution into the difference equation, we find:
\(\displaystyle \left(Aj^2+Bj \right)-\left(A(j-1)^2+B(j-1) \right)=j\)
\(\displaystyle 2Aj-(A-B)=j-0\)
Equating coefficients, we find:
\(\displaystyle 2A=1\,\therefore\,A=\frac{1}{2}\)
\(\displaystyle A-B=0\,\therefore\,B=A=\frac{1}{2}\)
Hence:
\(\displaystyle p_j=\frac{1}{2}j^2+\frac{1}{2}j=\frac{j(j+1)}{2}\)
Thus, the general solution is:
\(\displaystyle S_{j}=h_j+p_j=c_1+\frac{j(j+1)}{2}\)
Now we may determine the parameter:
\(\displaystyle S_{1}=c_1+\frac{1(1+1)}{2}=c_1+1=1\,\therefore\,c_1=0\)
Thus, the solution satisfying the given conditions is:
\(\displaystyle S_{j}=\frac{j(j+1)}{2}\)
This number is referred to as the $n$th triangular number, and may be written as a binomial coefficient:
\(\displaystyle t_n=\frac{n(n+1)}{2}=\frac{(n+1)!}{2!((n+1)-2)!}={n+1 \choose 2}\)
Now, we want to find the sum of the spheres in all the layers, thus we may use the difference equation:
\(\displaystyle T_{k}-T_{k-1}=\frac{k(k+1)}{2}\) where \(\displaystyle T_1=1\) and \(\displaystyle 1\le k\le n\)
\(\displaystyle h_k=c_1\)
and we should expect a particular solution of the form:
\(\displaystyle p_k=Ak^3+Bk^2+Ck\)
\(\displaystyle \left(Ak^3+Bk^2+Ck \right)-\left(A(k-1)^3+B(k-1)^2+C(k-1) \right)=\frac{1}{2}k^2+\frac{1}{2}k\)
\(\displaystyle 3Ak^2+(-3A+2B)k+(A-B+C)=\frac{1}{2}k^2+\frac{1}{2}k+0\)
\(\displaystyle 3A=\frac{1}{2}\,\therefore\,A=\frac{1}{6}\)
\(\displaystyle -3A+2B=\frac{1}{2}\,\therefore\,B=\frac{1}{2}\)
\(\displaystyle A-B+C=0\,\therefore\,C=\frac{1}{3}\)
And so we have:
\(\displaystyle p_k=\frac{1}{6}k^3+\frac{1}{2}k^2+\frac{1}{3}k= \frac{k^3+3k^2+2k}{6}= \frac{k(k+1)(k+2)}{6}\)
\(\displaystyle T_k=h_k+p_k=c_1+\frac{k(k+1)(k+2)}{6}\)
\(\displaystyle T_1=c_1+\frac{1(1+1)(1+2)}{6}=c_1+1=1\,\therefore\,c_1=0\)
\(\displaystyle T_k=\frac{k(k+1)(k+2)}{6}\)
And so, we may state:
\(\displaystyle N=T_n=\frac{n(n+1)(n+2)}{6}=\frac{(n+2)!}{3!((n+2)-3)!}={n+2 \choose 3}\)
This number is referred to as the $n$th tetrahedral number, or triangular pyramidal number.
b) To find the height of the stack, consider connecting the centers of the 4 spheres at each vertex with a line segment, each of length $(n-1)d$.
Now, to find the height $h_T$ of the resulting tetrahedron, we may drop a vertical line segment from the apex to the base and label its length $h_T$. Next draw a line segment from the apex down one of its faces bisecting the face, and we find its length $\ell$ from \(\displaystyle \sin\left(60^{\circ} \right)=\frac{\ell}{(n-1)d}\,\therefore\,\ell=\frac{\sqrt{3}}{2}(n-1)d\).
Now, observing that the vertical line $h_T$ intersects the base in the middle (the point equidistant from the 3 vertices), we can find the length of the line segment $b$ joining $h_T$ and $\ell$ by dividing the equilateral base into 3 congruent isosceles triangles each of which has an area \(\displaystyle \frac{1}{3}\) that of the equilateral base:
\(\displaystyle \frac{1}{2}b(n-1)d=\frac{1}{3}\cdot\frac{1}{2}\sin\left(60^{\circ} \right)((n-1)d)^2\)
\(\displaystyle b=\frac{1}{3}\cdot\frac{\sqrt{3}}{2}(n-1)d=\frac{1}{2\sqrt{3}}(n-1)d\)
Now we have a right triangle whose legs are $h_T$ and $b$ and whose hypotenuse is $\ell$, thus from the Pythagorean theorem, we obtain:
\(\displaystyle h_T=\sqrt{\ell^2-b^2}=\sqrt{\left(\frac{\sqrt{3}}{2}(n-1)d \right)^2-\left(\frac{1}{2\sqrt{3}}(n-1)d \right)^2}\)
\(\displaystyle h_T=(n-1)d\sqrt{\frac{3}{4}-\frac{1}{12}}=(n-1)d\sqrt{\frac{2}{3}}\)
Now, observing that we need to add 1 more spherical diameter to account for the radii below and above the tetrahedron, we then may state:
\(\displaystyle h=h_T+d=(n-1)d\sqrt{\frac{2}{3}}+d=d\left((n-1)\sqrt{\frac{2}{3}}+1 \right)\)
FAQ: How many spheres are in a tetrahedral stack and what is its height?
1. What is a tetrahedral stack of spheres?
A tetrahedral stack of spheres is a geometric arrangement of spheres where four spheres are placed at the corners of a regular tetrahedron (a polyhedron with four triangular faces), with each sphere touching the other three spheres. This structure is commonly used in scientific experiments and simulations to model the behavior of particles in a confined space.
2. How is a tetrahedral stack of spheres created?
A tetrahedral stack of spheres can be created by arranging four spheres in the shape of a regular tetrahedron, with each sphere touching the other three spheres. This can be done manually, or through computer simulations and modeling.
3. What are the applications of a tetrahedral stack of spheres in scientific research?
A tetrahedral stack of spheres has various applications in scientific research, such as studying the behavior of particles in a confined space, understanding the properties of materials, and simulating the behavior of molecules in chemical reactions. It is also used in the development of new technologies and materials.
4. How does the arrangement of spheres in a tetrahedral stack affect its properties?
The arrangement of spheres in a tetrahedral stack can greatly affect its properties. For example, changing the size or number of spheres in the stack can alter the packing density, which can affect the overall strength and stability of the structure. The arrangement can also affect the flow of particles and the diffusion rates within the stack.
5. Are there any limitations to using a tetrahedral stack of spheres in scientific experiments?
While a tetrahedral stack of spheres is a useful model for studying certain systems, it may not accurately represent real-world scenarios. The spheres in the stack are assumed to be perfectly spherical and do not account for factors such as particle shape, surface roughness, and interactions between particles. Additionally, the size and number of spheres in the stack may be limited by computational power or experimental constraints.
