MHB How many stickers does Xinyi have
  • Thread starter Thread starter Johnx1
Siti and Xinyi initially had the same number of stickers, but after Siti gave away 55 and Xinyi threw away 15, Xinyi had three times as many stickers as Siti. The equations set up to solve the problem were misinterpreted, leading to confusion about the variables. The correct approach involves defining the initial sticker counts and adjusting for the stickers given away to find the final counts. Ultimately, the correct answer is that Xinyi had 60 stickers after the exchanges. Continued practice and clarification of the equations are encouraged for better understanding.
Johnx1
Siti and Xinyi had the same number of stickers. After Siti gave away 55 stickers and Xinyi threw away 15 stickers. Xinyi had three times as many stickers as Siti. How many stickers did Xinyi have in the end?
My answer:
Siti = S
Xinyi = X
Gave/threw away stickers = TWe know:
S = X
S = T - 55
X = T -15
X = 3Sso, in short, I did elimination.
S = T - 55
-(3S = T - 15)
so, S = 20
Answer = 60.
My question is, is there a better way to do this besides elimination?
Mathematics news on Phys.org
Johnx said:
Siti and Xinyi had the same number of stickers. After Siti gave away 55 stickers and Xinyi threw away 15 stickers. How many stickers did Xinyi have in the end?. Xinyi had three times as many stickers as Siti. How many stickers did Xinyi have in the end?
My answer:
Siti = S
Xinyi = X
Once again, "Siti" and "Xinyi" are people, not numbers. You mean "S is the number of stickers Siti had initially" and "X is the number of stickers Xinyi had initially". I have no idea what you mean by setting "T" equal to "Gave/threw away stickers" since that phrase is used twice in reference to two different numbers.
We know:
S = X
yes, initially Siti and Xinyi had the same number of stickers.
S = T - 55
X = T -15
These make no sense at all. I don't know what number "T" refers to.
X = 3S
You are making the same mistake you did in the previous problem. "X" is the number of stickers Xinyi had initially, not after giving away stickers. It should be clear that the two equations "X= S" and "X= 3S" can't both be true (unless X= S= 0).
Initially Xinyi had X stickers and Siti had S stickers and X= S because they had the same number of stickers. After Xinyi threw away 15 stickers, Xinyi had X- 15 left. Do you understand that? After Siti gave away 55 stickers, Siti had S- 55 left. NOW Xinyi had 3 times as many stickers as Siti: X- 15= 3(S- 55).
You need to solve the two equation X= S and X- 15= 3(S- 55). Since X= S, the simplest thing to do is replace X by S in X- 15= 3(S- 55): S- 15= 3(S- 55). Solve that equation for S.
S = T - 55
-(3S = T - 15)
so, S = 20
Answer = 60.
The answer to what question? How did you go from "S= 20" to "Answer is 60"? You never say what 'S' represents but, from your first equation, apparently 'S' was the number of stickers Siti had initially. The question asked was 'How many stickers did Xinyi have in the end?' If S= 20 then you are saying that Siti had 20 stickers initially and Xinyi had the same number, 20. If Xinyi then "threw away 15 stickers" how could Xinyi have 60 at the end? Frankly it looks like you are going through all that calculation randomly, then copying the 'answer' from the back of the book.
It is not a question of "a better way". Unfortunately pretty much nothing you have done here is correct. You appear not to have a clear idea of what the letters you write as variables represent and are writing down equations with no logical reason. You really need to talk to your teacher who hopefully can help you get a better idea of how to convert sentences to equations.
A and B have the same number of stickers. [1]
A gives away 55 stickers and B gives away 15 stickers. [2]
B now has 3 times as many stickers as A. [3]
How many stickers does B now have? [4]
a = A's stickers at start, b = B's stickers at start
[2]: A now has a-55 stickers, B now has b-15 stickers
[3]: b-15 = 3(a-55)
b-15 = 3a - 165
3a - b = 150
[1] Since a=b:
3b - b = 150
2b = 150
b = 75
[2] Since B now has b-15 stickers:
b - 15 = 75 - 15 = 60 [4]
Thanks for pointing that out.
I skipped a few steps a few steps, but I times X = 3S, so that's how I got my answer.
I'm not trying to cause any drama, but I'm actually not a student and have no teachers. In short, I'm just currently not good at these yet, but this forum helps a lot :-)
Thank you for all your help, I really appreciate it.
Then keep working and posting here. You are improving!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
