How Many Types of Temperature Measurement Are There?
In summary, there are several methods of temperature measurement, including mechanical, electrical, and radiation-based devices. Some companies also offer colorimetric and cryogenic temperature measurement devices. It is important to note that infrared/non-contact temperature probes do not measure an exact temperature and require certain assumptions and calibrations. Additionally, there is a method called nuclear orientation thermometry that uses nuclear decay to measure temperature.
soonsoon88
54
Temperature measurement can be categorize into...how many ?
Temperature measurement by mechanical effect..
Temperature measurement by electrical effect..
Temperature measurement by radiation..
am i right ?
Science news on Phys.org
chemical
am i right ?
Interesting question.
Omega Engineering has a *large* book on temperature measurement devices. Most of the devices measure electrical changes (thermistors, thermocouples, RTD (resistance temperature detector)), mechanical changes (glass bulb thermometers), or spectroscopic (optical) detectors. They also offer colorimetric indicators (thermochromic dyes). There's also a section on cryogenic devices- most are RTD, but I imagine there are some exotic technologies (paramagnetism?) once you get below 1 K.
Finally, there are triple-point devices which serve as temperature standards (and I think can be used to measure temperature as well by measuring the vapor pressure)- I'm not sure how best to characterize them.
http://www.omega.com/literature/
Something to note- infrared/non-contact temperature probes don't really measure a temperature- they measure a 'temperature equivalent' and require certain assumptions and calibrations.
Temperature measurement via nuclear decay (Nuclear orientation thermometry).
Not quite the same thing as "radiation" (even if what you detect is gamma radiation).
FAQ: How Many Types of Temperature Measurement Are There?
What is temperature measurement?
Temperature measurement is the process of quantifying the degree of hotness or coldness of an object or environment. It is typically expressed in units of degrees Celsius (°C) or Fahrenheit (°F).
How is temperature measured?
Temperature can be measured using various instruments such as thermometers, thermocouples, infrared sensors, and thermistors. These instruments work by detecting changes in physical properties, such as expansion or electrical resistance, that are affected by temperature.
What is the difference between contact and non-contact temperature measurement?
Contact temperature measurement involves physically touching the object or surface being measured with a temperature sensor, while non-contact measurement uses sensors that can detect temperature without making direct contact. Non-contact measurement is often preferred for safety reasons and when measuring objects that are difficult to access.
How accurate is temperature measurement?
The accuracy of temperature measurement depends on the instrument being used and the environment in which it is being used. For example, a high-quality digital thermometer may have an accuracy of ±0.1°C, while an infrared sensor may have an accuracy of ±2°C. Environmental factors such as air flow and humidity can also affect the accuracy of temperature measurement.
Why is temperature measurement important in science?
Temperature is a crucial parameter in many scientific experiments and processes. It can affect the behavior of substances and chemical reactions, and is also an important indicator of the health and safety of living organisms. Accurate temperature measurement allows scientists to make informed decisions and draw meaningful conclusions from their research.
