How many values of k can be determined, such that
In summary: C(13) = 2.In summary, the number of values of k that can be determined in general, such that (k/p) = ((k+1)/p) = 1, where 1 <= k <= p-1, is equal to the number of quadratic residues modulo the odd prime p.
coolusername
36
How many values of k can be determined in general, such that (k/p) = ((k+1) /p) = 1, where 1 =< k <=p-1?
Note: (k/p) and ((k+1)/p) are legendre symbols
Question is more clearer on the image attached.
On image.
I've tried C(7)=#{1} and it equals to 1 set or C(7) = 1 and
C(13) = #{3, 9} = 2
I also plugged in p = 4n+1 into C( p) which makes it equal n-1.
As well, p = 4k+3 into C( p) makes it equal to n.
This in fact does make the above equation of C( p) true. But how do I show that it works for all prime p that are odd?
There is a lot of stuff in here that I have never worked with.
Perhaps you could provide a little more in the line of relevant equations or properties of the Legendre Symbols.
e.g.: http://mathworld.wolfram.com/LegendreSymbol.html
In general,
(8)
if
is an odd prime.
Using this, ##\left( \frac ap \right) = 1 \implies a^{(p-1)/2} \mod p = 1## and ##\left( \frac {a+1}{p} \right) = 1 \implies (a+1)^{(p-1)/2} \mod p = 1##
I see you have already worked out the first few...and noticing a pattern, perhaps induction might work...but that is quite tricky with primes.
For example,
3 has quadratic residues {1} , C(3) = 0.
5 has quadratic residues {1,4}, C(5) = 0.
7 has quadratic residues {1,2, 4}, C(7) = 1.
11 has quadratic residues {1, 3, 4, 5, 9}, C(11) = 2
Related to How many values of k can be determined, such that
1. How do you determine the values of k in a scientific experiment?
The values of k in a scientific experiment can be determined through various methods such as statistical analysis, mathematical equations, and experimental data. It is important to carefully design the experiment and control for any potential variables in order to accurately determine the values of k.
2. Can the values of k change over time?
In some cases, the values of k can change over time due to external factors such as environmental changes or the introduction of new variables. It is important to regularly reassess and analyze the experiment in order to accurately determine any changes in the values of k.
3. How many values of k can be determined in a single experiment?
The number of values of k that can be determined in a single experiment depends on the complexity and design of the experiment. In some cases, only one value of k may be determined, while in others multiple values may be determined.
4. Are there any limitations to determining the values of k?
Yes, there can be limitations to determining the values of k. These can include experimental errors, limitations in technology or equipment, and the complexity of the experiment. It is important to acknowledge and address these limitations in order to accurately determine the values of k.
5. How can the values of k be used in scientific research?
The values of k can be used in various ways in scientific research. They can help to determine relationships between variables, calculate measurements and predictions, and provide insight into the underlying mechanisms of a phenomenon. The values of k are an essential part of the scientific process and can help to further our understanding of the world around us.
  • Math Proof Training and Practice
  • Differential Equations
