How much closer was the Moon say 200,000 years ago?
In summary, the Moon is slowly receding from Earth at a rate of approximately 38 millimeters per year. Despite its seemingly small magnitude, this recession is the result of a constant conversion of lunar orbital momentum into tidal effects on Earth and is not influenced significantly by impacts on the moon's surface. The change in distance is not noticeable to the human eye, but is a significant factor in the long-term relationship between Earth and the Moon.
stany
24
much difference?
Astronomy news on Phys.org
[...] this causes the Moon to slowly recede from Earth at the rate of approximately 38 millimetres per year.
(Wikipedia)
so what would dat be?
You can't calculate it yourself? Make an effort. This isn't a place to have things spoon-fed to you.
4.7 miles
you think that would make the moon appear much closer? i mean if suddenly the moon appeared 5 miles closer would you notice?
how far is the moon away from the earth?
384,403 kilometers is the number i got for an average. 4.7 miles is about 7 kilometers.
would you notice a change of 7 kilometers if you were almost 400 000 kilometers away?
Is there any way to prove it has been moving away at this exact speed for that long? 38 millimeters a year is barely anything, so wouldn't some of the millions of impacts along the surface influence its direction?
yes.
you have fantastic depth perception then.
The effect of the impacts is miniscule becaues they make up a tiny fraction of the mass of the moon. 200,000 years is a pretty short time, so it is unlikely that it has changed much in that time.
Interesting question, even though, I think, it's based on a misconception. The recession is not an inertial but a friction effect, namely the result of a constant conversion of lunar orbital momentum into tidal effects on Earth. So, counteracting this effect by bombarding the moon with impactors would be not like changing the direction of a rolling car by throwing balls at it, which is tedious but easily doable given enough balls, but like trying to keep the car from eventually stopping due to energy loss, which is much harder in the long run.
Quantitatively, the figure means that the Moon's distance from Earth increases by one part in 10^10 per year, which roughly corresponds to a change in orbital speed by the same fraction, so the annual change in momentum is
delta p ~ lunar mass * change in lunar orbital speed ~ 10^23 kg * 10^3 m/s / 10^10 ~ 10^16 kg m/s
The typical speed of an impactor is on the order of tens of kilometres per second, so counteracting this would require an asymmetric bombardment on the order of 10^12 kg per year. I wasn't able to find a cumulative figure anywhere, but several publications gave total impact masses for certain impactor size ranges, and all of those were in the range of 10^3 to 10^6 kg per year per mass decade (i.e. impactor mass between 10^n and 10^(n+1) kg), so I'm guessing the grand total won't exceed 10^9 kg. And most of that is symmetric, so the momentum contributions will cancel each other out.
So, the answer seems to be that the effect of impacts is negligible in comparison with that of tidal losses, unless I made a major mistake somewhere.
Related to How much closer was the Moon say 200,000 years ago?
1. How do scientists determine how much closer the Moon was 200,000 years ago?
Scientists use various methods to determine the distance between the Moon and Earth in the past. One method is by studying the geological records and analyzing the impact craters formed by meteorites on the Moon's surface. Another method is by using lunar laser ranging, which measures the current distance between the Moon and Earth and then calculates the average rate at which the Moon has been moving away from Earth.
2. Was the Moon significantly closer to Earth 200,000 years ago?
Yes, the Moon was significantly closer to Earth 200,000 years ago. Based on scientific evidence, it is estimated that the Moon was around 22,000 km closer to Earth than it is today. This distance may not seem like much, but it had a significant impact on Earth's tides and the length of a day.
3. Why was the Moon closer to Earth 200,000 years ago?
The Moon's orbit around Earth is not a perfect circle, but rather an elliptical shape. This means that the Moon's distance from Earth varies throughout its orbit. 200,000 years ago, the Moon was at a point in its orbit known as perigee, where it is closest to Earth. Over time, the Moon's orbit has expanded due to the gravitational pull of the Sun, causing it to move further away from Earth.
4. How did the Moon being closer to Earth affect the planet?
The closer distance of the Moon had a significant impact on Earth's tides. With the Moon being closer, its gravitational pull on Earth was stronger, causing higher and more frequent tides. This also affected the rotation of Earth, as the Moon's gravity slowed down the planet's rotation, making a day last longer than it does now.
5. Will the Moon continue to move further away from Earth?
Yes, the Moon will continue to move further away from Earth at a rate of about 3.8 cm per year. This is because of the tidal forces between Earth and the Moon, causing the Moon's orbit to expand. However, the rate at which the Moon moves away from Earth is gradually slowing down, and it is estimated that it will continue to do so for the next few billion years.
