How much does weight affect re-entry into the atmosphere?
In summary, weight has a significant impact on reentry as a heavier vehicle will take longer to slow down in the atmosphere. This is taken into consideration when determining the best angle for re-entry and designing ancillary gear such as braking parachutes. However, the specific trajectory and weight calculations may vary depending on the purpose of the reentry, whether it is to recover the vehicle or ensure a satellite mostly burns up.
stacks
Sorry if this is a dumb question. How much of an impact does weight have on reentry? I know it's extremely important on lift off due to fuel costs but is it any different on reentry? Are there certain trajectories calculated for different weights?
Astronomy news on Phys.org
A more massive vehicle has greater inertia which it must dispose of to reach the ground safely.
It will take longer for the atmosphere to slow it down.
I guess this is factor which is taken account when determining the best angle for re-entry, and it would also be a consideration when designing ancilliary gear need for re-entry, such as the braking parachutes.
(This is assuming that the plan is to recover the vehicle and it's contents, in other cases the plan would be to ensure that a re-entering satellite does mostly burn up and poses a minpmum risk of large parts arriving on the ground.
Related to How much does weight affect re-entry into the atmosphere?
What is re-entry into the atmosphere?
Re-entry into the atmosphere is the process in which an object or spacecraft returns from space to Earth's atmosphere.
Why does weight affect re-entry into the atmosphere?
The weight of an object or spacecraft affects re-entry into the atmosphere because it determines the amount of force needed to slow down and descend safely through the atmosphere. Too much weight can cause the object to burn up or crash upon re-entry.
How does weight affect the speed of re-entry?
Weight affects the speed of re-entry because a heavier object will have more gravitational force pulling it towards Earth, causing it to accelerate faster as it enters the atmosphere. This can lead to higher temperatures and increased drag, making it more difficult to control the descent.
What is the optimal weight for re-entry?
The optimal weight for re-entry depends on the design and materials of the object or spacecraft. Generally, a lighter weight will result in a slower and safer re-entry, but it also depends on the speed and angle of re-entry.
How do scientists determine the weight limit for re-entry?
Scientists determine the weight limit for re-entry through extensive testing and analysis. They take into account the speed, angle, and materials of the object or spacecraft, as well as the atmospheric conditions and potential risks. They also use computer simulations to predict and optimize the re-entry process.
