How much energy could I create with a given amount of rpm?
  • Thread starter ShaneGarcia7
  • Tags
    Energy Rpm
In summary, the person is looking for help with their personal project involving a device that can produce 65 rpm with 70 lbs of force on each revolution. They are seeking to find a generator that can produce the most electricity per revolution given the strength of the motor, and want to know the average electrical output and ratio of input to output. They also ask about the energy created and the efficiency of the generator. The conversation also includes discussions about torque, horsepower, and efficiency.
ShaneGarcia7
I'm doing a personal project and need some help on things I could not find just on the Internet.
If I have a device that can produce 65 rpm with 70 lbs of force on each revolution, and the drive shaft was connected to a generator...(here come the questions, and I know that the numbers will be incredibly small)
- what generator out there would produce the most electricity per revolution given the strength of the motor per revolution? In other words, what is the biggest generator that could still be moved by that much force?
- what is the average electrical output of this device per revolution or per minute?
- (if you don't feel like doing the calculations for me) what is the average rpm of the given generator and what is ratio of revolutions of input to electrical output?
Thanks for the help.
None.
Energy is not created nor destroyed.
What does this mean? When and how is the force being applied? Is this force needed to overcome losses due to friction and so maintain a constant angular velocity?
Oh OK - you appear to want a generator that provides no more than 70lbs in drag... I think the details are important.
With no generator, the device spins up to 65rpm, and it takes 70lbs applied somewhere before it starts to slow down?
With a generator, it will spin up to, probably, less than 65rpm - at which point the drag from the generator will keep it at a constant speed.
What is happening, and this is important to your question, is that your whatsit is being supplied energy somehow. When the generator removes energy at the same rate, the thingy turns at a constant speed. If it draws energy faster, then the thingy will slow down. So the limiting factor is the rate that energy is being supplied to the thingy, and the efficiency of the generator.
http://www.mpoweruk.com/energy_efficiency.htm
... that should get you thinking properly.
Obviously energy cannot be created or destroyed. What I'm asking is what is a specific type of generator that does not take more then 70lbs (the equivalence of 70lbs) of force to revolve once, and with that specific engine how much energy is converted into useful electric energy per revolution (in wH/revolution).
And I have answered that question.
Enjoy.
Error - That doesn't compile.
Force applied where ?
go back to internet,
look up definitions of force, torque and work.
Then get your calculator
horsepower = torque X rpm / 5252
Maybe he means 70 ft-lbs of torque. In that case Torque X RPM is a unit of power, which is the most "electricity" you can get out of it at 100% efficiency.
Thank you good sir, << Rest of comment deleted by Mentor >>
Nobody is trolling you.
The questions and suggestions are sincere and based on, not just what you say, but years (sometimes decades) of experience answering this sort of question.
Have you followed any of the suggestions or considered any of the questions?
Perhaps even just letting us know if Curl's "maybe" is correct?
If so then it remains only to pick the motor with the efficiency you want (see link post #2 for examples).
Insults will not be tolerated here.
FAQ: How much energy could I create with a given amount of rpm?
How does rpm affect energy creation?
The amount of energy created by a given rpm depends on the specific system and its efficiency. In general, higher rpm can result in greater energy output, but there may be limits to how fast a system can rotate before it becomes less efficient.
Is there a formula for calculating energy created from rpm?
Yes, the basic formula for calculating energy is E = 1/2 * I * ω^2, where E is energy, I is moment of inertia, and ω (omega) is angular velocity, which is directly proportional to rpm. However, this formula may need to be adjusted for specific systems.
Can different types of energy be created with different rpms?
Yes, the type of energy created depends on the type of system and its design. For example, an engine may create mechanical energy with high rpm, while a wind turbine may create electrical energy with low rpm.
How can I increase energy output with a given rpm?
There are a few ways to increase energy output with a given rpm. One way is to increase the efficiency of the system, which can be achieved through design improvements or using higher quality materials. Another way is to increase the rpm, but this may have limitations depending on the system.
What are some real-world examples of energy creation using rpm?
There are many real-world examples of energy creation using rpm. Some common examples include wind turbines, which use the rotation of blades to generate electricity, and car engines, which use the rotation of pistons to power the vehicle. Generators, fans, and other rotating systems also use rpm to create various types of energy.
