How much energy is produced during thermal expansion?
In summary, the expansion coefficient of steel is 12 × 10 -6 m/m°C, Young's modulus 210 × 109 N/m2, and yield stress 250 mega Pascal. Using the first formula, the energy produced by expansion force would be 252 × 106 Joules. However, the energy density calculation may not be accurate as it does not take into account the square of the strain. The second formula, which uses the yield stress, results in a much smaller energy production of 0.3 × 106 Joules. It is also unclear if the yield stress would even be reached by increasing the temperature by 10 °C. Ultimately, it is difficult to determine the exact amount of energy produced by expansion
R.Mesri
661
We say the expansion coefficient of steel is 12 × 10 -6 m/m°C, Young's modulus 210 × 109 N/m2 and yield stress 250 mega Pascal. With 100 meters length and 0.1 m2 section area , If we increase its temperature 10 °C, how much energy will be produced by expansion force in Joules?
with young's modulus the answer is:
E= 12 × 10 -6 × 100 m × 10 °C × 210 × 10 9 × 0.1 m = 252 × 10 6 Joules
with yield stress the answer is :
E= 12 × 10 -6 × 100 m × 10 °C × 250 × 10 6 × 0.1 m = 0.3 × 10 6 Joules
I have been confused that which one could be right?
Science news on Phys.org
It may be that neither is right.
The energy density depends on the square of the strain. I don't think you have it in the first formula,
For the second, why would you even use the yield stress? Do you know that it reaches the yield limit by increasing the temperature by 10 degree?
In piping and mechanical engineering the force of a heated steel bar or pipe calculates by Young's modulus multiply by expansion coefficient. On the other hand the yield strength is the maximum force can be applied to a metal without deforming it after that point the plastic deformation begins. I would like to know how much real energy could be get from an expansion. When I use yield strength, the resulting amount looks very small.
FAQ: How much energy is produced during thermal expansion?
1. What is thermal expansion?
Thermal expansion is the phenomenon in which the volume and dimensions of a material increase in response to a change in temperature.
2. How is energy produced during thermal expansion?
Energy is produced during thermal expansion as a result of the particles within a material gaining kinetic energy and moving further apart, causing an increase in volume and the production of energy.
3. What factors affect the amount of energy produced during thermal expansion?
The amount of energy produced during thermal expansion is affected by the initial temperature and the temperature change, as well as the type of material and its coefficient of thermal expansion.
4. How is the amount of energy produced during thermal expansion calculated?
The amount of energy produced during thermal expansion can be calculated using the formula Q = α * m * ΔT, where Q is the amount of energy produced, α is the coefficient of thermal expansion, m is the mass of the material, and ΔT is the change in temperature.
5. What are some practical applications of understanding the energy produced during thermal expansion?
Understanding the energy produced during thermal expansion is important in various applications such as in the design of bridges, buildings, and pipelines, as well as in the development of thermal engines and power plants. It is also crucial in the manufacturing of products that are required to withstand temperature changes, such as car engines and electronic devices.
