How much energy is require to remove a small amount of CO2 from the atmosphere?
J. This is much less than the energy required to remove one molecule of CO2, which highlights the difficulty and energy-intensive nature of removing excess CO2 from the atmosphere.In summary, to remove a small amount of CO2 from the atmosphere, equivalent to the excess CO2 released by human activity, we would need approximately 30 kJ per molecule of CO2. This is significantly more energy than what is released by burning one atom of carbon to form one molecule of CO2.
mooneyes
Estimate how much energy is required to remove a small amount of CO2 from the atmosphere if we were to do a clean-up operation to take back greenhouse gas released into the atmosphere by human activity. Give the estimate in energy per molecule of CO2. Compare this with the energy released by burning one atom of carbon to form one molecule of CO2. Assume the concentration of CO2 in the atmosphere is 400 ppm. The heat of combustion of carbon is 30 kJg-1
(Carbon 12) + 2(Oxygen 16) → (Carbon dioxide)
  • It says to remove a small amount, so I assume this to be 1 kg.
    I then want to work out how much energy is in a CO2 molecule.
    Then compare this to the energy in individual C and 2 O atoms.
    The difference is the energy required to remove one CO2 molecule.
    Work out the mass of CO2 and scale up the energy difference
This was my general train of thought but I doesn't involve either of the given quantities; the 400 ppm or the heat of combustion! Should I be using the 400 ppm as the "small amount" I want to remove? Any help is appreciated.
Hello, thank you for your question and for taking the time to think through a solution. You are on the right track with your thinking, but let me clarify a few things for you.
First, we need to define what is meant by "a small amount" of CO2. In this context, it is referring to the excess CO2 that has been released into the atmosphere due to human activity. This excess CO2 is what contributes to the greenhouse effect and climate change. So, we need to estimate how much energy would be required to remove this excess CO2 from the atmosphere.
Now, let's look at the given concentration of CO2 in the atmosphere, which is 400 ppm (parts per million). This means that for every million molecules in the atmosphere, 400 of them are CO2 molecules. So, if we were to remove all of the excess CO2 from the atmosphere, we would need to remove 400 molecules of CO2 for every million molecules in the atmosphere.
To calculate the energy required to remove these 400 molecules of CO2, we need to first determine the mass of CO2 in the atmosphere. This can be done by using the concentration and the known mass of the Earth's atmosphere, which is approximately 5.15 x 10^18 kg. Multiplying these two values together gives us a total mass of CO2 in the atmosphere of approximately 2.06 x 10^15 kg.
Next, we need to determine the energy required to remove 1 kg of CO2 from the atmosphere. This can be done by using the heat of combustion of carbon, which is 30 kJg^-1. Multiplying this value by the mass of CO2 in the atmosphere gives us a total energy of approximately 6.18 x 10^16 kJ.
Finally, to determine the energy required to remove 400 molecules of CO2, we can simply divide this total energy by 2.06 x 10^15 (the number of kg of CO2 in the atmosphere). This gives us an energy requirement of approximately 30 kJ per molecule of CO2.
Now, let's compare this to the energy released by burning one atom of carbon to form one molecule of CO2. To do this, we need to first determine the mass of 1 atom of carbon, which is approximately 1.99 x 10^-23 g. Using the heat of combustion of carbon, we can calculate the energy
Related to How much energy is require to remove a small amount of CO2 from the atmosphere?
1. How is the energy required to remove CO2 from the atmosphere calculated?
The energy required to remove CO2 from the atmosphere is calculated based on the amount of CO2 to be removed, the method of removal, and the efficiency of the removal process. It can be calculated using various equations and models that take into account these variables.
2. What is the most efficient method for removing CO2 from the atmosphere?
The most efficient method for removing CO2 from the atmosphere depends on various factors such as cost, scalability, and environmental impacts. Some commonly used methods include direct air capture, carbon sequestration, and ocean fertilization. However, there is currently no single method that is considered the most efficient in all aspects.
3. How much energy is required to remove a small amount of CO2 from the atmosphere?
The amount of energy required to remove a small amount of CO2 from the atmosphere varies depending on the method used and the amount of CO2 to be removed. Generally, the energy required for direct air capture is estimated to be around 100-500 kWh per ton of CO2 removed. However, this can vary significantly depending on the specific technology and process.
4. What are the potential consequences of removing CO2 from the atmosphere?
While removing CO2 from the atmosphere can help mitigate climate change, it can also have potential consequences such as energy consumption, cost, and environmental impacts. Additionally, removing CO2 too quickly or in large amounts can disrupt natural carbon cycles and affect ecosystems. Therefore, careful consideration and research must be done before implementing large-scale removal methods.
5. Is removing CO2 from the atmosphere a sustainable solution for reducing greenhouse gas emissions?
Removing CO2 from the atmosphere can be a useful tool in reducing greenhouse gas emissions, but it is not a standalone solution. It should be combined with other strategies such as reducing emissions at their source and promoting sustainable practices. Additionally, the sustainability of CO2 removal methods must be carefully evaluated to ensure they do not cause more harm than good.
  • General Discussion
