How much force to drag an object?
  • Thread starter c131frdave
  • Tags
    Drag Force
In summary: Thus, the downward force (F) will be 300kg * (1.5m/s) = 525N. This is the total downward force needed to drag the object.
c131frdave
Hi. I'm not a student, and I'm old, so I don't remember physics class in high school. So I apologize for my question.
I'm trying to figure out how you would translate aerodynamic drag to someone like me- a layman. I have a wing on my car that, if I were to tilt it to 25 degrees angle of attack, would produce 120 pounds of downforce at 70mph, but would also produce 48 pounds of drag. I was trying to explain the problem of drag to a good friend, and I'm having trouble equating that to something he can appreciate.
If I'm thinking correctly, this 48 pounds of drag would be like attaching a rope on the back of the car and dragging a 300 pound chunk of steel down the road since the drag from friction would be about 48 pounds. But how do I determine exactly how much a chunk of steel must weigh to equal 48 pounds of friction drag? I assume that contact surface would be a determining factor aslo.
Thanks for your help!
How about working out the horsepower wasted pushing the wing through the air?...
Sorry but it's fastsest for me to work in SI/metric so..
48lbs = 22kg
Force in Newtons = 22 * 9.8 = 216N
Velocity = 70mph = 31m/s
Power in watts = force * velocity = 216 * 31 = 6700 W
Then ..
6700/750 = about 9 Horsepower.
PS Google suggests 30-35hp is needed for most cars to do 70mpg so that 9hp is a significant percentage.
You need the coefficient of friction between steel and a road. This is a dimensionless value, relating the contact force (300 pounds * gravitational acceleration) to the force of friction. As a good approximation, the coefficient does not depend on the velocity or the surface area.
Thanks for the replies. Yes, I figured I'd need to know the coefficient of friction. How do I figure that out? :D
Thanks for the hp figure. That is helpful to be sure. But I was hoping we could further illustrate it by saying it takes 9hp to drag X pounds of iron down a paved road. Or, in other words, 48 pounds of aerodynamic drag is equal to pulling a steel anchor weighing X pounds down the road. (Yes, it's silly, but we who put wings on our cars are by definition, silly... lol)
Test it (not on a public road please :D) or look it up in a table.
The additional force downwards will add friction as well - the wheels of your car are probably better than steel sliding on a road, but it is not negligible.
FAQ: How much force to drag an object?
1. How is force measured when dragging an object?
Force is measured in units called Newtons (N). This unit is determined by multiplying the mass of the object (in kilograms) by its acceleration (in meters per second squared).
2. What factors affect the amount of force needed to drag an object?
The amount of force needed to drag an object depends on its mass, the surface it is being dragged on, and the coefficient of friction between the object and the surface. Objects with greater mass and higher coefficients of friction require more force to move.
3. Does the direction of force affect how an object is dragged?
Yes, the direction of the force applied to an object affects how it is dragged. If the force is applied in the same direction as the movement of the object, it will accelerate in that direction. If the force is applied in the opposite direction, it will slow down or stop the object.
4. How does the surface affect the amount of force needed to drag an object?
The surface an object is being dragged on can greatly affect the amount of force needed. A smooth surface with low friction, such as ice, requires less force to drag an object compared to a rough surface with high friction, such as sand or gravel.
5. Can the amount of force needed to drag an object change?
Yes, the amount of force needed to drag an object can change depending on the external forces acting on the object. For example, if an object is being dragged on a surface with a constant slope, the force needed will decrease as the slope becomes steeper. Additionally, changes in mass or surface conditions can also affect the amount of force needed to drag an object.
