How much force to throw an object vertically?
  • I
  • Thread starter theboom
  • Tags
    Force
In summary: The object is on the platform and the only force that is applied is the force of gravity. So if you want to move the object a certain distance then you would have to apply a force greater than the gravitational force.
theboom
Say you have a platform, and on that platform you have an object the weighs 10,000lbs (ignore the weight of the platform itself). If the platform is only allowed to move vertically 6” before it must stop moving, how much upward force would be needed to throw the 10,000lb object 12” in the air? Also ignore air resistance.
Is this problem for schoolwork? If not, what is the application? How do you "throw" a 10,000 pound object?
It was a discussion that I saw recently but I changed the numbers. Obviously you can’t personally throw it but say you had some sort of mechanical device that was doing it, how much force would be needed? I changed the numbers because I wanted to see the effect of higher weight and limited travel distance of the force.
The question itself is incomplete. For example, what causes the platform to move? Is it supported by a spring? If so, what is the stiffness, or spring constant of the spring? If it is on concrete, why should it even move?
Secondly, how quickly do I have to lift the object? I can have the Hulk slowly lift it up 12" in the air, or I can put dynamites underneath the object and explode them, causing the object to jump up in the air very quickly. Each one of these scenario will produced different "impulse" and will cause different amount of reaction force being applied to the platform.
Zz.
Zz.
I’ll put a method to it. Say the platform in sitting on a solid object at rest but underneath the platform is hydraulic rams. The stroke of the ram is only 6” so all of the upward force will have to be exerted on the object in the time it takes the ram to move 6” and within that 6” distance. How much would be needed to throw the object a further 12” into the air above the platforms final point (so 18” total above the original starting point, 12” above the platforms ending point).
I think this is doable. Work out the speed needed for the 6” throw. Then you need to accelerate the load over the bottom 6” at acceleration x to get that speed in 6”. The force needed will be (x+g)Times the mass.
There are other approaches but that way gives understandable (?) steps I think.
I assume you use the maximum lifting distance.
Likes theboom
Again, how "stiff" is this hydraulics? And how fast do you want me to lift this? If I lift it very slowly, the platform will hardly move!
Zz.
Zz.
Don’t really understand your stiff question. When the platform is at its starting position, the hydraulic is not exerting any force on the platform so “zero stiff” I guess? Secondly, as far as speed, that’s part of my question. Obviously if you accelerate slowly the platform won’t be thrown at all. It will rise the 6” with the platform and stop when the platform does. I’m asking what force will be needed to generate the speed needed for a 10,000lb object to overcome the 9.8m/s/s of gravity enough to reach 12” of height before it starts coming back down.
Yes this is exactly right and what I’m trying to figure out.
@ZapperZ I think the design should follow the requirements, not the other way around. And if the OP doesn't care about the acceleration profile, we might as well assume a constant force is applied. The problem becomes easy then.
This is a fairly straightforward exercise using Newton's classical mechanics. Are you familiar with how the laws of motion work? d=st, v=at, etc?
To start with, do you know how to calculate the required velocity? Here's a hint: It's the same on the way up as the way down.
Likes CWatters and gmax137
I’m somewhat familiar with them, although it’s been a bit since I practiced it. I’m assuming it’s higher than 9.8m/s? I can’t really remember.
You'll need to actually look up equations and calculate stuff here. Guessing or hoping someone gives you the answer isn't going to work. If you know the relationships between acceleration, speed and distance, post the equations, start manipulating them and see if you can work it out. We'll nudge you if necessary.
Likes sophiecentaur
The first task is to calculate how fast the object must be traveling to go 12" (which is about 30cm in new money) into the air.
Does the equation ##u^2 = 2gh## look familiar?
No I don’t remember that one. Let me try that. I got 13.372mph..
That doesn't look right. You can in fact, solve this without any calculations.
If you assume a constant acceleration for the first phase, where the object is accelerated through a distance ##d##, then we also have:
##u^2 = 2ad##
Where ##a## is the required acceleration.
You can then use the relationship between ##d## and ##h## to get the g-force required. No numbers required.
Likes jbriggs444
Related to How much force to throw an object vertically?
1. How does the weight of an object affect the amount of force needed to throw it vertically?
The weight of an object does not affect the amount of force needed to throw it vertically. The force required to throw an object vertically is solely dependent on the height and speed at which the object needs to be thrown.
2. What is the formula for calculating the force needed to throw an object vertically?
The formula for calculating the force needed to throw an object vertically is F = m x g x h, where F is the force, m is the mass of the object, g is the gravitational acceleration (9.8 m/s^2), and h is the height or distance the object needs to be thrown.
3. Can the force needed to throw an object vertically be increased by throwing it harder?
Yes, the force needed to throw an object vertically can be increased by throwing it harder. The harder an object is thrown, the greater the initial velocity and force exerted on the object, resulting in a higher trajectory.
4. Is the force needed to throw an object vertically the same as the force needed to throw it horizontally?
No, the force needed to throw an object vertically is not the same as the force needed to throw it horizontally. The force needed to throw an object horizontally is dependent on the air resistance and the angle at which the object is thrown, while the force needed to throw an object vertically is solely dependent on the height and speed at which the object needs to be thrown.
5. Can the force needed to throw an object vertically be reduced by using a lightweight object?
Yes, the force needed to throw an object vertically can be reduced by using a lightweight object. According to the formula F = m x g x h, the force needed is directly proportional to the mass of the object. Therefore, a lighter object will require less force to be thrown vertically compared to a heavier object.
  • Other Physics Topics
  • Mechanical Engineering
  • Classical Physics
