How much force will get this thing moving?
  • Thread starter forgot
  • Tags
    Force
In summary: A thing with a resistance, whatever that thing might be. But I am pretty sure that energy is something that things have, and isn't something that can exist in its own right. Rather like the color red: something can be red, but you can't have red on its own. And "energy" maybe stops people from thinking about what things are.
forgot
if there is an object with zero inertia, and there are very strong forces pulling at the thing all around, but the forces all cancel each other out (so the object stays staionary) will it take any effort to start it moving?
i find myself being able to argue both ways.. help
If I'm understanding your question correctly, then the answer is the same as if the object did have inertia. Any imbalance in the forces, or addition of another one, will cause a displacement.
Danger,
It would not be the same. In Forgot's scenario, the force to move his object is 0, which is why the conundrum exists. If the object had mass, however, we can plug in numbers to get a real force.
[tex]\mbox{no inertia}\;F=0\quad \mbox{has inertia}\;F>0[/tex]
The two forces are therefore not equal.
Forgot,
Though your question is unanswerable, the important thing, and perhaps what Danger meant to say, is that all of the forces, being in balance, equal a net force of 0. Which means it would be the same situation if no forces where applied at all.
I would suggest the only possible way to conceptually answer this question is to state that since the F=ma equation is unresolvable, the only possible explanation is that the object is traveling at C.
Your object is a photon!
I see what you mean, Why, but I'm confused. Forgot specified that the object remains stationary, so it has to have mass. I have no idea how he expects something with mass to have no inertia, but that's beside the point for now. Something without mass, as you said, must travel at light-speed (as far as I know). So even if the inertia is zero, wouldn't some input be required to move mass? :confused:
forgot said:
if there is an object with zero inertia, and there are very strong forces pulling at the thing all around, but the forces all cancel each other out (so the object stays stationary) will it take any effort to start it moving?
A rehash: If we imagine the object has very small inertia but is stationary because the forces acting upon it are in balance, it won't take much effort to get it moving. If it had even less inertia it would take even less effort. You can carry on with this, but if you go all the way to zero you have to ask what those forces acting upon it have got to bite on. It's a bit like dividing by zero, things don't make sense any more.
Farsight,
That is an interesting observation.
Are the following considered to be true:
All matter has mass.
All mass has inertia.
To remove inertia, hence mass, hence matter, means to convert it to energy.
Energy has no inertia.​
Curious to hear the answers to those...
I'm not too sure about answering that, WhyIsItSo. Maybe matter, mass, and inertia are all different ways of looking at the same thing. A thing with a resistance, whatever that thing might be. But I am pretty sure that energy is something that things have, and isn't something that can exist in its own right. Rather like the colour red: something can be red, but you can't have red on its own. And "energy" maybe stops people from thinking about what things are.
if an object has no inertia, it means that there would be no reluctance to motion, which means that object would need to be massless, and traveling at the speed of light, c.
at c, the photons are not accelerating, and hence there is no net force. if you apply a force, they can't accelerate either. neither will they slow down, as there is only one speed that they can go.
thus, the object would not be stationary as in your question.
WhyIsItSo said:
Farsight
energy has no inertia? photons have momentum, which can be loosely related to inertia, so that solves the problem of the conservation of momentum.
(just making a wild guess)
FAQ: How much force will get this thing moving?
What is the formula for calculating force?
The formula for calculating force is F = m x a, where F represents force, m represents mass, and a represents acceleration.
How does an object's mass affect the amount of force needed to move it?
An object's mass directly affects the amount of force needed to move it. The greater the mass, the more force is required to move it at a certain acceleration.
Is there a limit to how much force can be applied to an object?
Yes, there is a limit to how much force can be applied to an object. This limit is known as the object's maximum static friction and is dependent on the surface it is resting on.
Can multiple forces act on an object at the same time?
Yes, multiple forces can act on an object at the same time. These forces can either work together or in opposite directions, depending on the direction and magnitude of each force.
How can I determine the minimum force needed to move an object?
The minimum force needed to move an object is determined by the object's mass and the coefficient of static friction between the object and the surface it is resting on. The formula for this calculation is F = μ x m x g, where μ represents the coefficient of static friction, m represents the mass of the object, and g represents the acceleration due to gravity.
14K
