How much ice to cool down this water?
In summary: Then I equated the two and took out the common factor of ##m##, so I ended up with:$$m = \frac{Q_w}{q_1 + q_2 + q_3}$$I find all those numbers get confusing. I prefer to let a computer do the arithmetic.You need to find the correct expressions for the three stages of what started as ice being heated.Homework Statement::Ice --> waterRelevant Equations::Q=c*m*∆TQ=m*Heat of fusion
Polarbear10
Ice --> water
Q=c*m*∆T
Q=m*Heat of fusion
Hello!
I'm having some problems solving a task..
"Ice with temperature -12°C is used to cool down water from 98°C. to 55°C. . Specific heat capacity for ice = 2097J/kgK, Secific heat capacity water: 4180 j/kgK. Heat of fusion for water is 334,4kJ7K. The mass of the water is 20kg."
∆T water = 55°C - 98°C = -43°C
∆T ice = -55°C - (-12°C) = 67°C
How much ice do we need to cool down the water?
The correct answer is supposed to be 6,1 kg of ice.
My thoughts: Heat gained + heat loss = 0 --> where ice melting (Q1) + icewater warming (Q2) (being the heat gained) and the heat loss being water cooling (Q3)
So I made these equations:
Q1: Heat of fusion water * mass of ice = 334400 * x = 334400x
Q2: Specific heat capacity for ice* m * ∆T = 2097 * 67 * x = 140499x
Q3: 20 * 4180 * -43 = -3594800J
Q1+Q2+Q3 = 0
334400x + 140499x - 3594800 = 0
474899x = 3594800
/474899 = /474899
x (mass of ice) = 7,57 kg
So I can't seem to get the correct answer.. is my ∆T for ice wrong?
Appreciate any help! :)
When the ice melts, it becomes water, so it no longer has the same heat capacity.
I tried using heat capaity for water, ended up with the mass of ice being 5,8kg..
You were not using the wrong number, you were using the wrong approach. Since ice water and liquid water do not have the same heat capacity, you need to divide the process in more steps.
Any tips on how I do it?o_O
The ice gets to freezing point, the ice melts, and then the waters mingle.
That's what I get. I took an algebraic approach and put the numbers in a spreadsheet. I didn't do any calculations myself.
I took ##Q_w## to be the heat lost by the water:$$Q_w = M\Delta T_3 c_w$$where ##M = 20 \ kg##, ##\Delta T_3 = 43 \ K## and ##c_w## is the specific heat of water.
Then, I took the mass of ice to be ##m## and calculated the three stages of heating:
$$Q = Q_1 + Q_2 + Q_3 = mq_1 + mq_2 + mq_3$$Then I equated the two and took out the common factor of ##m##, so I ended up with:$$m = \frac{Q_w}{q_1 + q_2 + q_3}$$I find all those numbers get confusing. I prefer to let a computer do the arithmetic.
Polarbear10 said:
Homework Statement:: Ice --> water
Relevant Equations:: Q=c*m*∆T
Q=m*Heat of fusion
Hello!
Q1+Q2+Q3 = 0
474899x = 3594800
/474899 = /474899
Think of all the steps that happen: The ice is warmed, then it melts, then the resulting water is warmed.
The heat to do these 3 things comes from the surrounding water, which cools off in the process.
Analyze the problem before you calculate.
See also the other answers you got!
Likes PeroK
I just can't seem to get the correct result.. what numbers did you get? I bet it would be easier using a computer yes, I just really want to learn how to do it on paper before using a computer. :smile:
So ok, the ice goes from -12, freezing, and into melting at 0°C..
For Q1, I then used the Heat of fusion water * mass of ice = 334400 * x = 334400x
Q2: Then the icewater heats up from the surrounding water from 0°C and up to 55°C. Using Specific heat capacity for water* m * ∆T = 4180* 55* x = 229900x
Q3: The water already there goes from 98°C and cools down to 55°C, using Specific heat capacity for water* m * ∆T => 20 * 4180 * -43 = -3594800J
Dividing Q3 on Q1+Q2 gives me 6,37kg of ice..
So I must be doing something wrong, or if there is something I'm forgetting..o_O
DrClaude said:
Du brukte ikke feil nummer, du brukte feil tilnærming. Siden isvann og flytende vann ikke har samme varmekapasitet, må du dele prosessen i flere trinn.
Do I need to make a Q4, for the process when the ice goes from 0-12°C? Using Specific heat capacity for ice* m * ∆T=> 2097*12 = 25164J
Then in the end, add together Q1+Q2+Q4 / Q3(The heat lost)
Q1 334400 +Q2 229900 + Q4 25164 = 589464J
Q3 = 3594800J
3594800J/589464J = 6,01 kg
Am I getting this one right?
Q3 = 3594800J
I guess you made a typo there: it should be 6,1 kg (6,09 kg rounded up), because otherwise it is correct.
Likes PeroK
Yes, I got 6.098 and rounded it up to 6,1kg. But the process is correct?
What is the real difference between Q1 and Q4?
With Q1 being: Heat of fusion water * mass of ice = 334400 * x = 334400J
And Q4: Specific heat capacity for ice* m * ∆T=> 2097*x*12 = 25164J
Because isn't both of these the energy used to take the ice from -12°C --> 0°C?
Okay, but your original post shows you drowning in a sea of numbers. You ought to treat algebra as a boat, to help you navigate the deep waters of university physics.
It's hard for me, as I have a particular inability to make sense of lines of digits. I really struggled to see what you were doing in your OP and spot your mistake.
Ultimately, however, your mistake seems to be to have forgotten that the ice needs to heat up from ##-12## degrees.
I can't see any real point in doing multiple long multiplications by hand in this day and age.
Likes Polarbear10
You're right, however on tests and on exams we are only allowed to use pen and papir and calculator. No computers.
Then the smart thing to do is to minimize calculation. Use algebra to get a formula. Then use the calculator to evaluate the formula.
Likes PeroK and Polarbear10
I don't know what marking schemes are employed, but I would be worried about submitting a page of numbers with the wrong number at the end and leaving it to the examiner to sift through the wreckage.
Instead, a well-thought out solution with a mistake in the final calculations ought to count for more.
I'd speak to someone in your physics department about whether you should be moving away from the "plug and chug" to a more mature, algebraic approach to physics problems. See what they say.
Likes kuruman
Amen to that. Students should spend their allotted test time thinking and instructors should evaluate understanding, not calculator prowess.
FAQ: How much ice to cool down this water?
How does the amount of ice affect the cooling of water?
The amount of ice used to cool down water affects the cooling rate because the ice has a lower temperature than the water. The more ice you use, the more heat it can absorb from the water, resulting in a faster cooling rate.
What is the ideal ratio of ice to water for optimal cooling?
The ideal ratio of ice to water for optimal cooling depends on the initial temperature of the water and the desired final temperature. Generally, a 1:1 ratio of ice to water is recommended for a significant temperature drop. However, for smaller temperature changes, a lower ratio may be sufficient.
Can adding too much ice make the water too cold?
Yes, adding too much ice can make the water too cold. If the water temperature drops below freezing point, the ice will start to melt and dilute the water, resulting in a lower overall temperature. It is important to monitor the temperature of the water while adding ice to prevent it from becoming too cold.
Does the shape or size of the ice cubes matter?
Yes, the shape and size of the ice cubes can affect the cooling rate of water. Smaller ice cubes have a larger surface area, allowing for faster heat transfer between the ice and water. Crushed ice can also cool water faster than larger ice cubes due to its increased surface area.
How long does it take for ice to cool down water?
The time it takes for ice to cool down water depends on various factors such as the initial temperature of the water, the amount and size of the ice, and the surrounding temperature. Generally, it can take anywhere from a few minutes to half an hour for ice to completely cool down water.
