MHB How much is the bicycle worth?
  • Thread starter Thread starter Marcelo Arevalo
    Bicycle
John agreed to work for 8 weeks for a total of $850 and a bicycle. After 5 weeks, he received $250 and the bicycle due to illness. To determine the bicycle's worth, equations were formed based on the total compensation for the work completed. Solving these equations revealed that the bicycle is valued at $750. The discussion concludes with a request to mark the thread as solved if the solution is satisfactory.
Marcelo Arevalo
John agreed to work after school for 8 weeks for a fixed weekly rate. But instead of being given only money for his work, John agreed to receive \$850.00 and a bicycle. After 5 weeks, John got sick. He was given \$250.00 and a bicycle. How much is the bicycle worth?
Mathematics news on Phys.org
I was working on this solution :
8 weeks = 850 + bicycle
5 weeks = 250 + bicycle
Solving for weekly rate :
850 / 8 + bicycle/8 = 250/5 + bicycle/5
850 /8 - 250/5 = bicycle/8 - bicycle/5
now I am stucked... am I doing the right thing??
please help. thank you.
Let y be the value, in cash, for the 8 weeks worked and let b be the cost of the bicycle. We can then form two equations:
y = 850 + b
and
5y/8 = 250 + b.
Subtracting the two equations, we have
y - 5y/8 = 850 + b - (250 + b) = 600, 3y/8 = 600.
Solving for y, we find y = 1600. With the equation y = 850 + b, b = 1600 - 850 = 750, so the bicycle is worth \$750.00.
* A note on using \$ signs here: Use \$ for the text following dollar signs to display correctly.
Wow! Thank you very much!
Hello, Marcelo Arevalo. If you are satisfied with any of the solutions given above (you seem to be), then I request you to use the thread tools to mark this thread as solved.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
