How much mass is needed to prevent an object from sliding down a ramp
In summary, if the object is not on the ramp, then 504 sandbags are needed to keep the box from sliding. If the object is on the ramp, then only 1008 sandbags are needed to keep the box from sliding.
physicsgirl199
An 80 kg object is on top of a 40°ramp and held by a box that is filled with sand bags. Each sand bag has a mass of 12 kg, the static friction coefficient between the box and the ramp is .507. What is the least amount of sand bags needed to prevent the object from sliding.
F,net,,x,object = 0 = F(box) - F(grav,x)
F(box) = F(grav,x,obj)
F,net,box = friction - F(object) - F(grav,x,box)
friction = μ(s)mgcos(40°)
F(grav,x,box) = mgsin(40°)
F(object) = mg(sin°40)
F(box) = F,grav,x,obj = 504 N
F,net,box = friction - F(obj) - F,grav,x,box
= > μ(s)mg(cos40) - 504 - mg(sin40) = 504
=> m[μ(s)gcos40 - gsin40] = 1008
=> m = 1008/(-2.49) = -404 kg ??
so lost
Is there no friction between the 80kg object and the ramp?
This looks like a trick question(providing all the data is correct).
Perhaps if you calculate the net force acting on the box parallel to the ramp, completely disregarding the 80kg body, you'll see why.
There is no information regarding static friction between the object and ramp..
If i disregard the object and focus on the box that is on the ramp, wouldn't the net force be 0 with friction and F,g,x cancelling each other out if it does not move?
As bandersnatch pointed out, just do a N2L for the box with the sand bags and mass M, ignore the 80kg object, and see what happens.
F box = friction - F,gx --> u(s)mgcos40 - mgsin40 = 0 --> factor out m --> m = 0??
If you factor out the m (and g) from your final equation you get
##mg(\mu_{s}cos(40) - sin(40)) = ma = 0##
If you plug in your known values, what does that tell you? (you're on the right track, just think about the implications)
Try dividing.
divide out m and your left with a negative acceleration meaning that box is moving meaning friction would not keep the box up on the ramp no matter what?
Looks that way.
Basically yea.
##\mu_{s}\text{cos}(40)## is always less than ##\text{sin}(40)## for the given value of mu s.
I calculate that there is an answer only when Θ < 26.885°.
That could be, I didn't go that far, but you need mu s cos theta >= sin theta which doesn't happen at 40 degrees.
Related to How much mass is needed to prevent an object from sliding down a ramp
1. What is the relationship between mass and friction in preventing an object from sliding down a ramp?
The greater the mass of an object, the more friction is needed to prevent it from sliding down a ramp. Friction is the force that opposes motion and is directly related to the weight or mass of an object. Therefore, a heavier object will require more friction to keep it from sliding down a ramp.
2. How does the angle of the ramp affect the amount of mass needed to prevent an object from sliding?
The steeper the angle of the ramp, the more mass is needed to prevent an object from sliding. This is because a steeper angle increases the force of gravity pulling the object down the ramp, making it more difficult to counteract with friction. As the angle of the ramp decreases, less mass is needed to prevent sliding.
3. Can the type of surface on the ramp affect the amount of mass needed to prevent sliding?
Yes, the type of surface on the ramp can greatly impact the amount of mass needed to prevent an object from sliding. A rougher surface will provide more friction and require less mass to prevent sliding, while a smoother surface will provide less friction and require more mass. Additionally, certain materials may have different coefficients of friction, which can also affect the amount of mass needed.
4. How does the force applied to the object affect the mass needed to prevent sliding?
The greater the force applied to the object, the more mass will be needed to prevent it from sliding down a ramp. This is because a greater force increases the object's acceleration, making it more difficult for friction to counteract and prevent sliding. Therefore, a smaller force would require less mass to prevent sliding.
5. Is there a specific formula for calculating the amount of mass needed to prevent an object from sliding down a ramp?
Yes, there is a formula that can be used to calculate the minimum amount of mass needed to prevent an object from sliding down a ramp. This formula takes into account the angle of the ramp, the coefficient of friction between the object and the ramp surface, and the force applied to the object. It is often written as: m = F*sin(θ) / μ*cos(θ), where m is the minimum mass needed, F is the applied force, θ is the angle of the ramp, and μ is the coefficient of friction.
