How much pressure for gasses to explode?
  • Thread starter Jasper Denarius
  • Tags
    Pressure
In summary, the amount of pressure required for a natural gas explosion is not the determining factor, but rather the concentration of the gas when mixed with air and the presence of an ignition source. Pressure can play a role in increasing the concentration of the gas, but most residential structures are not designed to withstand large pressure differentials, which can lead to collapse.
Jasper Denarius
I'm wondering about the amount of pressure required for natural gas (the kind pumped into homes for heating systems) to produce an explosion when exposed to an ignition source. Is there a formula of some sort to calculate this?
Specifically, if a town house (row home) were filled up with natural gas, say from a leak, about how much gas would need to leak into the home in order for the entire building to explode (not burn down, but explode), leaving no part of the structure intact? And how much pressure would this gas need to be under?
Would the amount of pressure normally provided by the home (as in the amount that regular oxygen-rich atmospheric air is under while in the home) be enough to cause this, or would some sort of additional containment be required to allow the gas to accumulate to such a degree?
I'm asking because this was an official story given for such an explosion that a friend of mine was affected by, but there were sketchy elements to the whole event, and I'm trying to figure some things out.
It's not a matter of pressure for creating the circumstances for a gas explosion, it's a matter of the concentration of the gas when mixed with the air inside the structure which is a critical variable.
Natural gas is composed primarily of methane plus some odorant in a small concentration. In order for methane gas to ignite, at normal atmospheric pressure, its concentration in air needs to be at least 4.4% by volume, with an upper limit of 15%-17%. If the concentration of methane is above or below these limits, no explosion will occur, even in the presence of an ignition source:
https://en.wikipedia.org/wiki/Flammability_limit
The ignition source also must be sufficiently energetic.
Of course, should the pressure be elevated for some reason, these limits may change. Unless this building were a pressure vessel of some sort, most residential structures are not designed to withstand large pressure differentials. Collapse of a structure can occur when as little as 2 psi over pressure is present (14 kPa).
https://en.wikipedia.org/wiki/Overpressure
Likes berkeman
Related to How much pressure for gasses to explode?
1. How is pressure related to gas explosions?
Pressure is one of the key factors that can contribute to gas explosions. When the pressure inside a container or vessel containing gas exceeds its structural limits, it can lead to an explosion.
2. What is the minimum pressure required for a gas to explode?
The minimum pressure required for a gas to explode depends on several factors, such as the type of gas, its concentration, and the environment it is in. Generally, the pressure needed for a gas to explode is at least three times its normal atmospheric pressure.
3. Can low pressure cause a gas to explode?
No, low pressure alone cannot cause a gas to explode. In fact, low pressure can actually prevent gas explosions by reducing the likelihood of a gas reaching its explosion point. However, if the pressure suddenly increases, it can lead to an explosion.
4. How can pressure be controlled to prevent gas explosions?
Pressure can be controlled by ensuring proper ventilation in areas where flammable gases are present. Additionally, regular maintenance and inspection of equipment that contains gases can also help prevent pressure buildup and potential explosions.
5. What are the warning signs of a potential gas explosion?
Some warning signs of a potential gas explosion include unusual smells or odors, hissing sounds, visible leaks, and changes in pressure readings. It is important to take immediate action if any of these signs are noticed to prevent a potential explosion.
  • Mechanics
  • General Engineering
  • Mechanics
