How much pressure is exerted on the hooves and ground when using jumping stilts?
  • Thread starter Pro-Jumper
  • Tags
    Pressure
In summary, the stilts have a surface area of 5935.472mm^2 and the time hooves are in contact with the floor is 2 seconds. The highest you can jump in them is 6 foot.
Pro-Jumper
Hi there
I am using a pair of pro-jump jumping stilts (spring loaded)
We are looking for an indoor hall for when it rains.
Does anyone know how to work out the approx. pressure on the hooves/ground when jumping?
The surface area of the bottom of the stilts is 5935.472mm^2 (length - 101.6mm, width - 58.42mm).
The time the hooves are in contact with the floor is 2 seconds.
Pro-Jumper said:
Hi there
Is it really the pressure that you want, or the force? Is there a limit for the loading allowed on the floor in the indoor hall, for example, and that's why you need to know?
And are you serious about the height being 6 feet :bugeye: That's how high the bottoms of the spring-loaded stilts get off the floor?
The force on the ground would be very helpful yes.
The floor is a sprung floor.
As far as I know there is no loading limit on the floor, broastcasts with full live audiences have been held in there for example.
There is however underfloor pipes and the owner wishes for us to prove that the downward force is not going to damage them before using the hall.
The video above shows the little effort put into jumping therefore I'm under the assumption that the majority of the forces are absorbed and given back by the spring.
The max height for the correct weight category is 6 feet yes.
Unexperienced users using heigher weight categories tend not to get much air, however experienced users with practised technique can get up to 8 (skill level very dependant).
Many thanks for your time once again with this matter
Hello,
Thank you for your inquiry. I would like to first clarify that the pressure exerted on the hooves and ground when using jumping stilts can vary depending on factors such as the weight and force applied by the individual, the surface of the ground, and the design and construction of the stilts themselves.
That being said, based on the information provided, we can estimate the pressure exerted on the hooves and ground using the formula P = F/A, where P is pressure, F is force, and A is area.
Assuming an average weight of 150lbs (68kg) and a force of 2 seconds, the pressure exerted on the hooves and ground would be approximately 0.28 pounds per square inch (psi). However, this is just an estimate and the actual pressure may vary.
I would also like to mention that the pressure exerted on the hooves and ground may increase when jumping at higher heights, as the force and weight applied by the individual is greater.
I hope this helps answer your question. Please keep in mind that this is just an estimate and the actual pressure may vary. Thank you.
FAQ: How much pressure is exerted on the hooves and ground when using jumping stilts?
What is the cause of pressure on hooves/ground?
The primary cause of pressure on hooves and the ground is the weight of the horse. As horses move and shift their weight, the pressure on their hooves and the ground beneath them changes.
How does pressure affect the horse's hooves?
Excessive pressure on a horse's hooves can lead to discomfort, pain, and even lameness. It can also cause damage to the sensitive structures within the hoof, such as the laminae and the bones.
Can the type of terrain affect the pressure on a horse's hooves?
Yes, different types of terrain can have varying levels of pressure on a horse's hooves. Hard and uneven terrain can put more pressure on the hooves, while softer and more even terrain can distribute the weight more evenly.
How can we reduce pressure on a horse's hooves?
Proper trimming and shoeing can help distribute the weight more evenly on a horse's hooves, reducing pressure. Regular exercise and maintaining a healthy weight can also help prevent excessive pressure on the hooves.
Is there a way to measure the pressure on a horse's hooves?
Yes, there are various tools such as hoof testers and pressure-sensitive pads that can measure the pressure on a horse's hooves. These can be useful for identifying any areas of high pressure and addressing any potential issues.
