How much reduction in temperature can be achieved?
In summary, if a cooling system of 2000 ton capacity is fitted to the Condenser, it can reduce the temperature in the Condenser by around 250 kW.
pranj5
386
I want put here an imaginary, but close to reality scenario. We have 3 MW power plant here having 1800 kg/hr or 0.5 kg/sec steam flow and the exhaust will be steam at 1 bara pressure and 100C temperature. If a cooling system of 2000 ton capacity is fitted to the Condenser, how much it can reduce the temperature in the Condenser?
It's not really close to reality, you'll end up with a lot of very very cold ice.
2000 cooling tons is about 7 MW - a lot of cooling power.
2000 ton of ice means extracting 2000X80X1000 kCal 16 million kCal of heat in a single day. In fact, I want to mean the cooler can convert 2000 kg or 2 ton of water to ice every hour and that means 48 tons of refrigeration. That by my calculations, it will take around 250 kW. Sorry for the mistake!
This is the kind of problem worked through by someone who's taken a college-level course in Thermodynamics. Based on your interests over the past weeks, have you considered taking a course and/or purchasing a textbook to increase your knowledge in this area?
Likes russ_watters, billy_joule and Nidum
billy_joule said:
The temperature won't be reduced, removing 250kW from the steam will only condense a fraction of the steam (about 112g/s) and reduce the quality;
https://en.m.wikipedia.org/wiki/Vapor_quality
http://m.wolframalpha.com/input/?i=250kW/+specific+heat+of+vaporization+water+&x=0&y=0
That is assuming the steam is saturated to start with.
I wouldn't mean that this system will just remove 250 kW of heat from the steam, but rather to get this 48 ton of refrigeration, the power consumption would be 250 kW.
48 tons of cooling is only 170 kW.
How much power your cooling system requires to achieve this cooling is irrelevant.
It makes no sense to use a refrigeration cycle to condense steam at a power plant. We just dump the waste heat directly to the atmosphere, river or lake.
I second mech engineer's suggestion, I'd recommend Thermodynamics by Cengal and Heat and Mass Transfer, also by Cengal.
Or at least start by reading this:
https://en.m.wikipedia.org/wiki/Thermal_power_station
The purpose of this process is to lower the temperature of the Condenser so that efficiency and output can be increased.
If it worked we'd already be doing it.
That can be said about any new innovative idea.
The condenser uses a process (probably either direct air or water to air heat exchanger) that requires less input power than a mechanical chiller, so adding a mechanical chiller would reduce the efficiency and output, not increase it.
It is nice that you are trying to think of ways to make existing systems more efficient, but I agree that it would be better if you started by learning how they work by taking a thermodynamics class. It will save you a lot of wasted effort.
That's true, but unfortunately you don't have any way to know if your ideas are new, innovative or even functional. Most are just wrong. People don't like hearing this, but it is the truth: new/innovative ideas almost never come from people who don't understand the subject they are investigating. So please do yourself and us a favor and make your time more productive by starting with more rigorous study of thermodynamics instead of continuing with all of this pointless idle speculation.
Thread locked.
Likes mheslep, billy_joule and Nidum
Related to How much reduction in temperature can be achieved?
1. How is temperature reduction measured?
Temperature reduction is measured in degrees Celsius or Fahrenheit using a thermometer. It can also be measured in Kelvin, which is an absolute temperature scale.
2. What factors affect the amount of temperature reduction that can be achieved?
The amount of temperature reduction that can be achieved depends on factors such as the initial temperature, the type and amount of cooling agent used, and the surrounding environment.
3. Can temperature reduction be achieved indefinitely?
No, temperature reduction cannot be achieved indefinitely. There is a limit to how much a cooling agent can reduce the temperature and the surrounding environment also plays a role in the final temperature.
4. How does the type of cooling agent affect the amount of temperature reduction?
The type of cooling agent used can greatly affect the amount of temperature reduction. For example, liquid nitrogen can achieve a much lower temperature than ice, resulting in a greater reduction.
5. Are there any safety precautions to consider when attempting to reduce temperature?
Yes, there are safety precautions that should be taken when attempting to reduce temperature. Certain cooling agents, such as liquid nitrogen, can be harmful if not handled properly. It is important to use caution and follow proper safety protocols when attempting to reduce temperature.
  • Mechanical Engineering
  • Classical Physics
