MHB How Much Should the Radius Increase to Enlarge the Circle's Area by b Units?
  • Thread starter Thread starter mathdad
    Increasing Radius
To determine how much to increase the radius of a circle so that the area increases by b units, the area formula A = πr^2 is essential. The correct approach is to set up the equation π(r + x)^2 = πr^2 + b, where x is the increase in the radius. The solution involves isolating x, leading to the expression x = √((πr^2 + b)/π) - r. It's crucial to ensure that the area and radius dimensions are not confused, as they represent different quantities. The discussion emphasizes the importance of correctly applying mathematical principles to solve the problem.
mathdad
The radius of a circle is r units. By how many units should the radius be increased so that the area increases by b units?
The information in this problem tells me that using the area of a circle formula is needed.
A = pi•r^2
I think b should be added to r and squared.
A = pi(r + b)^2
Can someone provide a one or two hints?
Mathematics news on Phys.org
A = pi•r^2
A = pi(r + b)^2
You certainly should not add $b$ to $r$, because $b$ is an area and $r$ is a distance. Adding a two-dimensional quantity to a one-dimensional quantity does not make sense.
What you want to know is how much to increase $r$ so that $\pi r^2$ becomes $\pi r^2 + b$. Suppose that $x$ is the amount that has to be added to $r$. Then the equation is $\pi(r+x)^2 = \pi r^2 + b$. So you need to solve that equation for $x$.
I understand what you are saying.
π(r + x)^2 = A + b
(r + x)^2 = (πr^2 + b)/π
sqrt{(r + x)^2} = sqrt{(πr^2 + b)/π}
r + x = sqrt{(πr^2 + b)/π}
x = sqrt{(πr^2 + b)/π} - r
Correct?
RTCNTC said:
π(r + x)^2 = A + b
sqrt{(r + x)^2} = sqrt{(πr^2 + b)π}
r + x = sqrt{(πr^2 + b)π}
x = sqrt{(πr^2 + b)π} - r
Correct?
The method is correct, but in the last three lines you should have $(\pi r^2 + b)/\pi$ instead of $(\pi r^2 + b)\pi$.
I just forgot to include the slash symbol in the last 3 lines. It has now been edited.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
