- #36
Drakkith
Mentor
- 23,044
- 7,425
Peter Mason said:The proposal is for a single photon sensor probably an avalanche diode because I have not found a SPAD device that is not connected to a piece of specialised electronics and presumed to cost a lot. That signal I can see on an oscilloscope although counting individual photons to produce rate signal is probably the final destination. I Know that if I receive a photon at the detector it can be counted I was more concerned that the rate of photon collection from a remote planet would be too low to be meaningful. Is there any data on photon data rates from these objects? Answer in Hz/m^2 at the aperture of the device before the glass, mirror, pin hole, fibre, or what ever please :-)
The main issue isn't with detecting the faint signal from the planet, it's with being able to distinguish the signal from the noise. Noise comes in many forms. Background light from the parent star, scattering and emission in the atmosphere, background stars, thermal noise in your sensor, and more. Professional setups typically have cooled sensors (reducing thermal noise), operate in very dark locations away from major cities (reducing background noise from light pollution), and block the light from the parent star (reducing the dominant source of noise, which is the star itself).
This is all in addition to having large apertures (increasing resolving power/resolution), high-precision guiding (to keep the image centered on the sensor), and some may have adaptive optics (to correct for atmospheric blurring of the image).
In light of all of those issues, having a sensor capable of detecting each and every photon should be the least of your concern. In fact, going from an efficiency of ~100% to ~20% isn't that big of a problem. It means you have to take more/longer exposures, but it also means that the noise from all of those sources except thermal noise is also reduced by the same ratio.
