member 534986
I have to build a new stand for our single compartment concrete laundry tub since two legs of original steel stand are corroded. I want to make the new stand out of angle aluminum to avoid corrosion and also because it's easier to cut and drill.
The laundry tub weighs about 135 lbs. I calculated the volume of the water in the tub when full to be 307 lbs. So the total weight will be about 442 lbs.
For reference, the legs of the original factory made stand are composed of steel angle bars that are 3/4" wide x 3/32" thick.
I want to use 1" wide x 1/8" think aluminum angle bars for the 4 legs and the horizontals on top of the legs to hold up the laundry tub. There will of course be diagonal supports on the stand to keep it from swaying and falling down. Plus the stand will be secured to the back wall and right side built-in cabinet to keep it from swaying.
So the challenge is to know whether four aluminum 1" wide x 1/8" thick x 17" high legs can support 442 lbs. To clarify, angle bars are "L" shaped in cross section, each side being 1" wide.
Thanks for any help,
HRG
HRG
