How much work does gravity do on the car
In summary, a car with a mass of 1500 kg rolls down a hill for a distance of 150 m at an angle of 15º with the horizontal. The amount of work done on the car by the force of gravity can be calculated using the formula W = fdcosθ, where f is the force, d is the distance, and θ is the angle. However, in this case, the force would be the weight of the car (mass times g) multiplied by the sine of the angle. The final calculation for the work done on the car is 571278 Joules, which may seem high due to the long distance traveled.
Brittykitty
81
A car of mass 1500 kg rolls down a hill for a distance of 150 m.
If the road makes an angle of 15º with the horizontal, how much work is done on the car by the force of gravity?
would I use the formula
W=fdcosº
w=(f)(150m)(15º)
For force would I convert 1500kg into Newtons and plug that into the formula?
I believe you're right about the force, but are you sure you're supposed to take the cosine of 15º? Since Work also equals the change in Potential Energy, it seems like you'd only want the vertical distane the car travels.
(note: not at all to scale)
y|``\ 150m
`|___(\<- 15º
```x
150m * cos 15 would give you x; multiplying 150m by either cos 75 or sin 15 would give you the proper value, depending on which way you like to do it.
Firstly, you need to get the component of the force in the direction of motion. It is not just as easy as Fdcosθ.
In this case, I think that you would need, at some point, to take the mass times g ( 9.8 m/s^2 )
I base this assumption on this fact: the unit of force is Newton, which is the same as kg - m/s^2
SO... W=(f)(d)cos(theta) as you said above. plug in the variables as you have said, expect use the weight (mass times g) for F...
Also, don't forget: work can also mean, more simply, change in energy. energy conservation usually provides an easier solution.
Hello :)
Thank you! So the correct equation would be:
w=(14715)(150m)(cos15)?
Brittykitty said:
Hello :)
Please draw over your free-body diagram, if you do, you will see why it is not cosine.
Would it be sin?
The force moving the car down would the the sine component of the force, or mgsin(theta)
Brittykitty said:
Would it be sin?
Yes it is sine but it is best to understand why it is sine and not cosine.
I agree. If you decompose the force of weight on the car, which would point striaght down, it breaks up into 2 parts: one parallel with the surface normal (or normal force) and one perpindicular to the surface normal. The one that is actually pulling the car down the slope is the force that is perpindicular to the surface normal. Here is a picture... I hope it helps...
http://www.facebook.com/photo.php?pid=268554&id=100000066426322
The picture helps a ton!
W=fdcos
w=(14715)(150m)(sin15)
w=571278
does that seem a bit high?
W=fdcos
w=571278
Yes that is correct. But remember that 150 m is a long distance so the work done will be high.
That is true, thank you so much Rock Freak :)
FAQ: How much work does gravity do on the car
What is the definition of work in relation to gravity and a car?
Work is defined as the product of the force applied on an object and the distance the object moves in the direction of the applied force. In the case of gravity and a car, work is the force of gravity pulling the car towards the ground and the distance the car moves in the direction of gravity.
How does gravity affect the movement of a car?
Gravity plays a significant role in the movement of a car as it pulls the car towards the ground. This force of gravity is what keeps the car on the road and allows it to accelerate, brake, and turn.
How can the amount of work done by gravity be calculated on a car?
The amount of work done by gravity on a car can be calculated by multiplying the force of gravity (which is equal to the car's mass multiplied by the acceleration due to gravity) by the distance the car moves in the direction of gravity.
Does the amount of work done by gravity on a car change if the car is going uphill or downhill?
Yes, the amount of work done by gravity on a car can change depending on whether the car is going uphill or downhill. Going uphill requires the car to work against the force of gravity, so more work is done compared to going downhill where gravity helps the car move.
Can a car perform work on itself due to gravity?
No, a car cannot perform work on itself due to gravity. Work requires an external force to act on an object, and in the case of gravity, the force is coming from the Earth and not the car itself.
