How Much Work Is Needed to Launch a Weather Monitor Into Space?
In summary, the work done against gravity to fire a 7.2*10^2 kg weather monitor 120km into the air is approximately 1.0*10^8 J. This is based on the calculation of the change in gravitational potential energy, with the assumption that the final kinetic energy is zero and the work done by gravity is equal to the work done by the person firing the monitor.
crosbykins
53
How much work is done against gravity to fire a 7.2*10^2 kg weather monitor 120km into the air.
Mass Earth = 5.98*10^24kg
radius of Earth = 6.38 * 10^6 m
Eg = -GMm/r
delta Eg = Eg 2 - Eg 1
Eg1= -[(6.67*10^ -11N * m2 /kg2 )(5.98*1024 kg)(7.2*102 kg)] /(6.38*106 m)
= -4.50 *1010 J
Eg2= -[(6.67*10^ -11N * m2 /kg2 )(5.98*1024 kg)(7.2*102 kg)] /(6.38*106 m + 120 *103 m)
= -4.49 *1010 J
delta Eg = -4.49 *1010 J - -4.50 *1010 J
= 1.0*108 J
***my solution is based off the idea delta Eg is equal to work done...is this correct?
you just need the monitor to reach the 120km distance
so you can imagine that its velocity there is 0
so ΔKE =0
so net work done on monitor is zero
so work done by you = -(work done by gravity)
hi crosbykins! :smile:
(have a delta: ∆ and try using the X2 icon just above the Reply box :wink:)
= -4.50 *1010 J
= -4.49 *1010 J
= 1.0*108 J
yes, but that 4.50 - 4.49 looks very inaccurate …
you should use at least two more significant figures in your intermediate calculations if you're gong to subtract two numbers that are so close :wink:
(btw, you could have avoided using G by using g = 9.81 and GM/R = R*GM/R2 = Rg, and then using R/(R+h))
Related to How Much Work Is Needed to Launch a Weather Monitor Into Space?
What is work done against gravity?
Work done against gravity refers to the amount of energy required to move an object against the force of gravity. This can be calculated by multiplying the force applied by the distance the object is moved.
How is work done against gravity different from work done by gravity?
Work done against gravity involves using external energy to move an object against the force of gravity, while work done by gravity refers to the energy transferred by gravity to an object as it moves towards the ground.
What is the formula for calculating work done against gravity?
The formula for calculating work done against gravity is W = F * d, where W is work, F is the force applied, and d is the distance the object is moved.
Why is work done against gravity important?
Work done against gravity is important because it helps us understand the amount of energy required to lift or move objects in everyday life. It is also essential in fields such as engineering, physics, and sports science.
How does the mass and height of an object affect the work done against gravity?
The mass and height of an object both have a significant impact on the work done against gravity. The greater the mass or height of an object, the more energy is required to move it against the force of gravity. This is because the force of gravity increases with mass and height.
