How much would time pass between watching the sun set ....?
B... = 1000In summary, the time difference between watching the sun set from ground level and then watching it set again from the top of a skyscraper, such as the Sears/Willis Tower or the Burj Khalifa, is approximately 2 minutes. However, attempting to convince someone who believes the Earth is flat with mathematical equations and demonstrations is likely a futile effort. It is important to remember that even if we can prove something with evidence and logic, some people will still refuse to believe it.
Xarzu
How much would time pass between watching the sun set from ground level and then watching it set again from the top of a sky scraper?
I heard once that this could be done using one of the towers of the World Trade Center. So I assume one could also do this using the Sears / Willis Tower in Chicago. Someone also told me that the world's tallest tower in Dubai is so huge that the local weather broadcast tells of two times for sunset. One time is for the observed sunset at ground level and another time is for the observed sunset from the observation deck near to the top of the tower.
unfortunately, I have recently gotten involved in a debate with someone who believes or claims to believe that the Earth is flat and he has challenged me for proofs. I gave him some observations that anyone can do, but that did not seem to be good enough for him. He wanted the mathematical predictions of an event and then a demonstration that showed that reality matches the mathematics.
Well, my math skills are a bit rusty on this sort of level since I have been out of college. Although I could probably do this, I figure it would be a greater ease for me to just ask one of the math majors or grad students that frequent online mathematics forums for the equations. So I think what I will do is list my ideas one at a time in this mathematical forum. And now, here is the first one.
The rapper B.O.B. has come out saying that he thinks the Earth is flat. Neil Tyson gave him a reply and PBS offered an Op Ed piece explaining some simple tests anyone can do to prove the Earth is round. One of them was to lay on the beach on your back and with your head pointed towards the sun set (do this on the pacific coast of course. The moment you see the sun set, immediately stand up and you can see the sun set again -- or so says the op ed piece from PBS. I have herd that something similar can be done with large buildings. If you watch the sun set on the ground level, (let's say from the point of view of a 6ft 4 man. Or some measured eye level from the ground) and then you take an elevator to the top floor, you will be able to see the sun set a second time.
The problem is this, if you know all of the variables, how long would it take to see the sun set a second time.
I hope I have posed this question well enough. Let me know if you have any questions. After this one is answered, I have at least one more question I will start in a second thread.-->
:welcome:
By my calculation, about 2 minutes difference for a 1000 foot skyscraper.
Edit: you don't have to measure time difference. Just look at the building or a mountain from a distance around sunset. You can watch the shadow climbing from bottom to top. The simplest explanation for that is that the Earth is round.
Likes davenn and Buzz Bloom
Unfortunately there is likely nothing you can present to him that would change his mind. I can't guarantee this, but in my experience, 99% of everyone I've ever dealt with who believed in non-scientific "theories" will not change their mind, regardless of the evidence or arguments you present to them. It's mind boggling to think that some people have developed an elaborate and nonsensical explanation for something as simple as the day-to-night cycle of the Earth when I can take a flashlight and a basketball and explain the cycle in 5 seconds. If they don't believe that the reason the Sun and star-field moves across the sky is because the Earth is round and rotating, something which absolutely screams "round earth" and requires nothing but a basic clock to measure, I don't know what would convince them.
Likes BvU
You are wasting your time. Of course, there are far worse ways to waste your time, so if you are enjoying the conversation then proceed. But the only participant that your arguments will convince is yourself.
Likes BvU
Did he present those for his theory?
I am going to go through with this. It is a good mental exercise if nothing else.
I did the math on my own. It took a while of pondering. And there is a good visualization tool that helped. Using this website https://www.desmos.com/calculator/zs5wfg9uem I was able to put in the equations for a circle, X 2 + Y 2 = radius 2 and then I put a line for where the light from the sun would be tangent to the circle ( Y = radius). Then with some calculations and trial and error and even a bit of C++ code, I came up with a function that would represent the straight line on which the CN Tower would reside and intersect the sunlight with the sky pod (the highest observation deck) on the CN tower would see the sun light. Now I only need to know one thing (and I might start a separate discussion thread for it). Here it is:
If I have an X and Y point on a grid that represents the intersection of two formulas: A straight line (aX = Y) where "a" represents a constant number with a circle (X 2 + Y 2 = radius 2, how would I convert that point into a degree of an angle?
Related to How much would time pass between watching the sun set ....?
1. How can I calculate the time between watching the sun set and sunrise?
The time between sunset and sunrise can be calculated by taking the total number of hours in a day (24 hours) and subtracting the duration of daylight, which varies depending on the time of year and location. This will give you the approximate amount of time that will pass between watching the sun set and sunrise.
2. Does the time between sunset and sunrise change throughout the year?
Yes, the time between sunset and sunrise changes throughout the year due to the tilt of the Earth's axis and its orbit around the sun. This creates longer days and shorter nights in the summer and shorter days and longer nights in the winter.
3. How does the location affect the time between sunset and sunrise?
The location can affect the time between sunset and sunrise because it determines the duration of daylight. Locations closer to the equator will have more consistent daylight hours throughout the year, while locations closer to the poles will experience more extreme changes in daylight hours.
4. Can you watch the sun set and rise at the same time?
No, it is not possible to watch the sun set and rise at the same time. This is because the sun appears to set when it dips below the horizon, which is caused by the rotation of the Earth. Similarly, the sun appears to rise when it emerges from below the horizon due to the Earth's rotation.
5. Is there a difference in the time between sunset and sunrise on different planets?
Yes, there is a difference in the time between sunset and sunrise on different planets. This is due to the varying lengths of days and years on different planets, as well as the position of the planet in relation to its sun. For example, on Mars, a day lasts approximately 24.6 Earth hours, so the time between sunset and sunrise would be slightly longer than on Earth.
  • Science Fiction and Fantasy Media
  • Other Physics Topics
  • Astronomy and Astrophysics
