How pH would affect the dative bonding
In summary, the concentration of Ca2+ in hard water can be determined by titration with a reagent X, similar in structure to an amino acid, which forms a complex with Ca2+ resulting in a color change. The titration must be carried out in an alkaline buffer due to the sensitivity of the color change to pH. This is because at a low pH of 4, the amino functionality of the amino acid exists as an ammonium ion and the carboxylic acid exists as an acid, making it less electron-rich and unable to form coordinate bonds with Ca2+. However, at a higher pH of 10, the carboxylic acid exists as COO- and can donate its lone pair to coordinate
Kushal
438
The concentration of Ca2+ in hard water can be determined by titration with a reagent X which forms a complex with Ca2+ giving a change in colour. Since the colour change is sensitive to pH, the titration has to be carried out in an alkaline buffer.
Th structure of X is similar to that of an amino acid. The way X acts as a ligand can be understood by considering how aminoethanoic acid forms co-ordinate bonds with a calcium ion.
Explain why the complex between aminoethanoic acid and aqueous calcium ions is more stable at pH 10 than at pH 4.
I really have no idea how pH would affect the dative bonding.
Well, as pH is based on how many hydrogen ions (and thus how few hydroxide ions) there are in the solution, I'd guess that hydroxide interferes in the bonding.
Remember that aminoethanoic acid is an amino acid. At pH 4 the amino functionality exists as an ammonium ion and the carboxylic acid exists largely as an acid (R-CO-OH).
Ligands are electron rich species and calcium in solution exists as a cation. Is an ammonium compound electron-rich? Is a carboxylic acid?
bah no...
the ammonium compound is not electron rich because it has already accepted a proton... right?? (the nitrogen lone pair is used in dative bonding)
at pH 4 the dissociation of the organic acid is repressed. it cannot donate its proton and therefore is not electron rich.
but at pH 10, the carboxylic acid exists as COO-. and the lone pair on the nitrogen can coordinate with Ca2+.
is this correct?
Yep.
nice, thnks!
Related to How pH would affect the dative bonding
1. How does pH affect dative bonding?
The pH of a solution can affect dative bonding by altering the charge of the atoms involved in the bond. When the pH changes, the concentration of hydrogen ions (H+) and hydroxide ions (OH-) also changes. This can cause changes in the partial charges of the atoms, leading to changes in the strength of the dative bond.
2. Can pH affect the stability of dative bonds?
Yes, pH can affect the stability of dative bonds. Dative bonds are formed between atoms with different electronegativities, resulting in a partial positive charge on one atom and a partial negative charge on the other. Changes in pH can alter the distribution of these charges, affecting the strength of the bond and potentially causing it to break.
3. How does the strength of dative bonds change with varying pH levels?
The strength of dative bonds can change with varying pH levels. Generally, as the pH decreases (becomes more acidic), the strength of the dative bond decreases. This is because the increase in hydrogen ions can disrupt the partial charges on the atoms involved in the bond, making it easier for the bond to break.
4. Can pH affect the reactivity of compounds with dative bonds?
Yes, pH can affect the reactivity of compounds with dative bonds. Changes in pH can alter the electron density and partial charges of the atoms, making the bond more or less likely to react with other molecules. This can also affect the overall chemical properties of the compound.
5. How does the pH of a solution impact the formation of dative bonds?
The pH of a solution can impact the formation of dative bonds by affecting the availability of electrons. In a more acidic solution, there are more hydrogen ions competing for electrons, making it more difficult for a dative bond to form. In a more basic solution, there are fewer hydrogen ions, making it easier for a dative bond to form.
