How powerful would an engine have to be to lift 150lbs?
In summary, the amount of energy or power needed to lift 150lbs with a jet engine or rocket depends on the thrust force generated by the engine, which should be slightly more than the weight of the engine and payload. Other factors to consider include the mass of the engine and propellant, the specific impulse and specific power of the engine, and the presence of other forces such as drag. Jet engines are more efficient for this purpose than rockets, as they can distribute the power over a larger area.
BigFly
just out of curiosity if i wanted to lift something about 150lbs out of the air with a jet engine or rocket, to hold it against the Earth's gravitational pull 9.8m/s how much energy/power would i need? would it also depend on how heavy the engine is? and what other factors are there in this problem?
Really just comes down to how many lbs of thrust the engine can put out. You need slightly more thrust than the weight of the engine and payload in order to go up. All just basic physics.
Want to build a jetpack? Just assuming since you said 150 lbs.
Might be handy to bring fuel as well.
You only need more thrust than the weight of your contraption if you need to go straight up. You could also use wings and you would only need 1/5 or so.
Yea, I wouldn't use power. Power is really just work per unit time. So, an infinitely small engine could be geared to lift the weight infinitely "fast". But rockets and jet engines are typically measured in thrust force, so you would really just need slightly more than the weight of the vehicle + fuel + weight. Excess force can be used to calculate a possible acceleration.
It all really depends on how high you want to go and how long burn time you have.
If you want to lift a total load of a 150lbs, you would need to engine to produce slightly above 150lbs of thrust in a focused direction.
One would have to consider all masses involved, i.e. not only the 150 lb payload (or person), but also the mass of the engine and propellent (fuel - and oxidizer if the engine is not airbreathing). If one want's to accelerate vertically, the thrust must exceed the total weight, or thrust/weight ratio must > 1.
Don't forget drag forces too.
which are roughly dependent on the magnitude of velocity squared, so if the thrust is barely above the total weight, then drag will not be significant.
Is the original question related to a jetpack?
http://www.popularmechanics.com/technology/transportation/4217989.html
Like other people said, the thrust has to be greater than 150 lbs.
To generate 150 lbs of thrust, the output power required depends on how fast you have to move the propellant to generate the force needed. A propellant that is moved faster to generate the same force will result in a higher specific impulse, which means it willl reduce amount of that propellant mass need to deliver the same momentum (e.g. ion propulsion rocket). However, to take advantage of that lower propellant mass, it will require more output power to generate the same force.
[PLAIN]http://en.wikipedia.org/wiki/Ion_thruster said:
The[/PLAIN] thrust created in ion thrusters is very small compared to conventional chemical rockets, but a very high specific impulse, or propellant efficiency, is obtained.
Due to their relatively high power needs, given the specific power of power supplies, and the requirement of an environment void of other ionized particles, ion thrust propulsion currently is only practicable in outer space.
In this sense, for your purposes, a jet engine would be far more efficient than a rocket. A fan of larger diameter would be even better in terms of efficiency, since it distributes the power over a larger swath of air, reducing the power needed to generate the same force. That's why helicopters don't use jet engines and why airliners don't use rocket engines.
But helicopters do use jet engines (gas turbines). Well said either way ;)
FAQ: How powerful would an engine have to be to lift 150lbs?
How is engine power measured?
Engine power is typically measured in horsepower (hp) or watts (W). Horsepower is the measurement of power developed by an engine, while watts measure the rate at which energy is transferred.
What factors determine the power required to lift 150lbs?
The power required to lift 150lbs will depend on several factors, including the weight of the object, the distance it needs to be lifted, and the speed at which it needs to be lifted. The force of gravity and the acceleration due to gravity (9.8 meters per second squared) also play a role in determining the power needed.
Can you provide an example of an engine's power output?
For context, a typical lawnmower engine has a power output of around 4.4 horsepower, while a car engine can range from 100 to 1000 horsepower depending on the make and model. A jet engine, on the other hand, can have a power output of up to 100,000 horsepower.
How does engine power affect fuel consumption?
The more powerful an engine is, the more fuel it will consume. This is because more power requires more energy, which is supplied by burning more fuel. However, newer engines are designed to be more efficient, so a more powerful engine may not necessarily consume significantly more fuel than a less powerful one.
Is there a limit to how powerful an engine can be?
Technically, there is no limit to how powerful an engine can be. However, there are practical limitations based on the materials and technology available. For example, the most powerful engine ever built, the Wärtsilä-Sulzer RTA96-C, has a power output of 108,920 horsepower. As technology advances, it is possible that even more powerful engines could be developed.
