Elquery
- 67
- 10
I have read numerous times that equilibrium vapor pressure (EVP) is a function ONLY of temperature. This at least partly makes sense to me (so I think) given energy of molecules and movement associated with such. But apparently this is not true for the partial pressures?
I once thought that even for partial pressures, it was only a function of temperature, but I am reading that system pressure has an effect.
See this source as one example: https://www.vaisala.com/sites/default/files/documents/Dew-point-compressed-air-Application-note-B210991EN-B-LOW-v1.pdf
"If this air is compressed and the total pressure is doubled to 2026.6 mbar, then according to Dalton’s law, the partial pressure of water vapor, e, is also doubled to the value of 5.6 mbar."
It is almost intuitive that pressurizing a system with increase the partial pressures, but on the other hand it feels strange to think that EVP would not be affected by pressure while partial pressure would, since EVP is just the 'maximum partial pressure for a given temperature.'
Furthermore, I thought that the ideal gas law in essence states that the pressure of one component is independent of the others. But clearly we are capable of compressing gases which compresses all partial pressures...
If I have this right, changing system pressure does not affect the maximum possible vapor pressure at that temperature, but it affects the actual pressure up to that maximum?
