How produce twin photons in practice?
In summary, producing twin photons typically involves the process of spontaneous parametric down-conversion (SPDC), where a nonlinear crystal is pumped by a laser beam, resulting in the generation of pairs of entangled photons. The key steps include selecting an appropriate nonlinear medium, optimizing the pump laser's wavelength and intensity, and using suitable optical components to filter and detect the twin photons. Practical considerations also involve ensuring phase matching conditions are met and minimizing losses during photon propagation. This technique is widely used in quantum optics and quantum information applications.
Quant
44
TL;DR Summary
Advice on production of twin photons
I would be very thankful if somebody helps me with some practical advices about producing twin photons?
I know that twins are produced after a laser ray is directed on a BBO crystal. After the BBO there are two rings of photons and the twins are in the intersection of the rings.
1. I wonder in order to get the two rings must I have the laser ray falling strictly at 90 degree to the BBO? My crystal is very small 3x3 mm so I intend to focus the laser on it which means I would have different angles of them on the BBO so I fear I would not get the rings but a smeared spot. Is this right and what to do? I would like the beam to fall on a point but to be perpendicular. Is there a way to do this?
2. I am not at all sure how to capture the light from the intersection of the rings where the entangled twins are. I will filter the incident beam 405 nm by a filter at 405 but how to collect only the intersection spots to proceed and to direct them to a beam splitter b.e.? To make a mask with two openings? Or fibers?
Thanks in advance.
I am going to assume you are taking about a second harmonic crystal, and because double 405 nm is 810 nm
your laser source is a laser diode. As long as you power is low enough, you should be able to get
a lens to collimate the beam, and then bring the beam size down to the size of the crystal.
Thank you. I see. Collimating is ok but how to bring the beam size to 2 mm. Of course I will use a lense to focus the beam to a point but then I must use a lense with very short focus distance (maybe 1 mm) to get a parallel beam after it which will have a diameter of 2 mm. Are there such lenses?
Beam ex panders work both ways, they can also make the beam diameter smaller.
Depending on the power level, you might want to avoid a real focal point, it takes less energy per square mm
to ionize air than you think.
Likes Quant
