How Safe Is The Constant Pressure Assumption For Enthelpy?
In summary: Khan's video on enthalpyIn summary, Khan uses enthalpy under constant pressure to explain the First Law of Thermodynamics. He states that this is the condition under which most chemical reactions occur. He argues that because pressure conditions around a reaction might not adhere to those of the environment, enthalpy should be used under conditions that approximate equilibrium.
DocZaius
365
I am curious about a statement that is usually tacked onto the end of a derivation showing enthalpy with constant pressure being equal to the heat into the system.
[itex]
\Delta U = Q - W_{by}
[/itex]
Define Enthalpy and look at its change:
[itex]
H=U+PV \\
\Delta H = \Delta U + \Delta (PV)
[/itex]
Plug in First Law:
[itex]
\Delta H = Q - W_{by} + \Delta (PV)
[/itex]
Under constant pressure:
[itex]
\Delta H = Q - P\Delta V + P\Delta V \\
\Delta H = Q
[/itex]
And here is the part that I've heard and read more than once (Khan uses it in his enthalpy video for example). It is said that considering enthalpy at a constant pressure is useful for us, since that is the condition under which most of our chemical experiments occur (e.g. those done inside test tubes, etc.). But I always wonder why we can say that. My intuition would be that when a chemical reaction occurs, particularly a violent one, the pressure conditions at the center of the reaction would not necessarily adhere to those of its environment. I understand that an open test tube would be connected to the atmospheric pressure of the room, but surely for a short period of time and under very local conditions (e.g. at the center of the reaction) there must be a significant pressure gradient around the reaction? I would think that force per area in surfaces considered around the reaction would be relatively high. And is it not during that short period of time and at that specific location that we are considering quantities such as enthalpy?
My intuition appears to be wrong in this case, since clearly people have been using enthalpy under constant pressure as a useful quantity for a long time. But I am curious why it is that before any equilibrium is reached, we can safely assume constant pressures in energetic chemical reactions.
Science news on Phys.org
You've not understood the basic assumption of all thermodynamics, which the consideration of systems under equilibrium. You need to go back to chapter 1 page 1 of your thermo book of choice and re-read this.
Shouldn't it be called thermostatics then? :P Anyhow, fair enough but if one got from point A (pre-reaction) to point B (post-reaction) under conditions that are clearly not quasi-static, I don't understand why we get to usefully apply these quantities that were derived assuming constant equilibrium.
In other words, I'm OK with my book announcing that the basic assumption will be that all considered systems will be under equilibrium. But I don't understand why it proceeds to tackle systems that clearly don't stay under equilibrium.
P.S. And does that mean then that this enthalpy-at-constant-pressure quantity would then only be useful for slow reactions that approximate equilibrium as best as possible?
Don't forget that the work done by the system on the surroundings for a closed system between two thermodynamic equilibrium states is always given by ##W=\int P_{Int} dV##, where PInt is the pressure at the interface with the surroundings (atmospheric pressure in your example). (See my recent Physics Forums Insight article https://www.physicsforums.com/insights/understanding-entropy-2nd-law-thermodynamics/). This equation applies irrespective of whether the process is reversible or irreversible, and/or how non-uniform the conditions are within the reaction vessel. Only in the case of a reversible process is Pext = P, where P is the pressure that one would calculate from the equation of state for the gas.
However, for an irreversible process, if the final equilibrium state of a system has been attained via spontaneous reaction at constant interface pressure (PInt), the final equilibrium pressure of the system Pfinal will be equal to PInt (which is the same as in the initial equilibrium pressure of the system). So, ##W=P_{final}ΔV=P_{Int}ΔV=PΔV##.
Chet
Related to How Safe Is The Constant Pressure Assumption For Enthelpy?
1. What is the constant pressure assumption for enthalpy?
The constant pressure assumption for enthalpy is a commonly used assumption in thermodynamics, which states that the pressure of a system remains constant during a process. This assumption is often used when analyzing systems that involve gases or liquids, as their volumes can change under constant pressure.
2. Is the constant pressure assumption for enthalpy always valid?
No, the constant pressure assumption for enthalpy is not always valid. It is a simplifying assumption that is often made for convenience and ease of calculation. In reality, many processes involve changes in pressure, and the constant pressure assumption may not accurately describe the behavior of the system.
3. How does the constant pressure assumption affect the accuracy of results?
The constant pressure assumption can affect the accuracy of results in some cases. If a process involves significant changes in pressure, the assumption may lead to significant errors in the calculated values of enthalpy. However, for processes where pressure changes are small, the assumption may have minimal impact on the accuracy of results.
4. Can the constant pressure assumption be applied to all thermodynamic systems?
No, the constant pressure assumption may not be applicable to all thermodynamic systems. It is commonly used for systems that involve gases and liquids, but it may not be suitable for systems that involve solids or phase transitions, where pressure changes may play a significant role in the behavior of the system.
5. What are some alternative assumptions to the constant pressure assumption for enthalpy?
Some alternative assumptions to the constant pressure assumption for enthalpy include the constant volume assumption, where the volume of the system remains constant during a process, and the isothermal assumption, where the temperature of the system remains constant. These assumptions may be more appropriate for certain types of systems, depending on the specific conditions and processes involved.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
