How should I show that solutions can be expressed as a Fourier series?
Math100
Consider the equation ## \ddot{x}+x+\epsilon(\alpha x^2\operatorname{sgn}(x)+\beta x^3)=0, 0<\epsilon<<1, \alpha>0, \beta>0 ##, where ## \alpha ## and ## \beta ## are constants, and the signum function, ## \operatorname{sgn}(x) ##, is defined by ## \operatorname{sgn}(x)=1 ## for ## x>0 ##, ## \operatorname{sgn}(x)=0 ## for ## x=0 ## and ## \operatorname{sgn}(x)=-1 ## for ## x<0 ##. With initial condition ## x(0)=0 ##, show that solutions with angular frequency ## \omega ## can be expressed as a Fourier series of the form ## x(t)=\sum_{k=1}^{\infty}B_{2k-1}\sin((2k-1)\omega t)=B_{1}\sin\omega t+B_{3}\sin 3\omega t+\cdots ##.
None.
Proof:
Let ## \epsilon=0 ##.
Then the unperturbed equation is ## \ddot{x}+x=0 ## and the general solution is
## x(t)=A\sin\omega t+B\cos\omega t ## where ## \omega=1 ## is the angular frequency
with the constants ## A ## and ## B ##.
With the initial condition ## x(0)=0 ##, we have that ## B=0 ##.
This gives ## x(t)=A\sin\omega t ## where ## A ## is a constant.
Note that the function of ## x(t)=A\sin\omega t ## is periodic and odd.
From the work/proof shown above, how should I show that solutions with angular frequency ## \omega ##
can be expressed as a Fourier series of the given form on the problem? What needs to be done?
Can you show the work you've done on this problem so far?
That's all the work I have so far.
OK, can you substitute the form ##x(t)=\sum_{k=1}^{\infty}B_{2k-1}\sin((2k-1)\omega t)=B_{1}\sin\omega t+B_{3}\sin 3\omega t+\cdots## into the differential equation to see what you can learn about ##\omega## and the coefficients ##B_{2k-1}##?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
