How should I show that the index of a limit cycle is ## 1 ##?
  • Thread starter Thread starter Math100
    Index
Math100
Show that the index of a limit cycle is ## 1 ##.
If ## \Gamma ## surrounds ## n ## equilibrium points ## P_{1}, P_{2}, ..., P_{n} ##, then ## I_{\Gamma}=\sum_{i=1}^{n}I_{i} ##, where ## I_{i} ## is the index of the point ## P_{i} ## for ## i=1, 2, ..., n ##.
Proof:
Consider the index of a limit cycle.
By definition, a limit cycle is an isolated periodic solution of an autonomous system represented in the phase plane by an isolated closed path.
The theorem states: If ## \Gamma ## surrounds ## n ## equilibrium points ## P_{1}, P_{2}, ..., P_{n} ##, then ## I_{\Gamma}=\sum_{i=1}^{n}I_{i} ##, where ## I_{i} ## is the index of the point ## P_{i} ## for ## i=1, 2, ..., n ##.
Let ## I_{\Gamma}=\frac{1}{2\pi}\triangle\theta_{\Gamma} ## where ## I_{\Gamma} ## is the index of the curve ## \Gamma ## and ## \triangle\theta_{\Gamma} ## is the total change in the angle of the vector field along ## \Gamma ##.
Note that the vector field along a limit cycle ## \Gamma ## behaves such that the direction of the vector field is always tangent to ## \Gamma ##.
Since the limit cycle traverses once, it follows that the vector field rotates once, and the total angular change of the vector field along the limit cycle is ## 2\pi ##.
Thus, ## I_{\Gamma}=\frac{1}{2\pi}\triangle\theta_{\Gamma}=\frac{1}{2\pi}(2\pi)=1 ##.
Therefore, the index of a limit cycle is ## 1 ##.
Above is the proof for this problem. May anyone please take a look and verify/confirm if it's accurate/correct?
The result follows essentially by inspection, but you should at least define the index of a closed curve \Gamma for the system (\dot x, \dot y) = (f_1,f_2) as <br /> \frac{1}{2\pi}\int_{\Gamma} d\arctan\left( \frac{f_2}{f_1} \right) = \frac{1}{2\pi}\int_{\Gamma} \frac{f_1df_2 - f_2df_1}{f_1^2 + f_2^2}.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
